R56 Sunroof Rattle
Old Jul 15, 2012 | 03:47 PM
Avantarch's Avatar
Avantarch
Sunroof Rattle
Hi all...we have a '09 MCS which we love...the only issue is a consistent rattle in the roof..yes, we have a sunroof...
It seems located in the center of cross member....
I have exhausted every effort to localize the problem but to no luck....including the dome light and the trim rings in the front and back...
Has anyone experienced the same and if resolved...HOW?
Old Jul 16, 2012 | 09:11 PM
bluefox280's Avatar
bluefox280
Are you sure it's not the retractable sun shade that's making the racket?
- Erik
Old Jul 17, 2012 | 05:16 AM
Avantarch's Avatar
Avantarch
This was my original thought but further investigation has emliminated it...probably something that will require removal of the whole unit to resolve....more than my DIY capabilities allow...
Old Jul 17, 2012 | 05:46 AM
alexs3d2's Avatar
alexs3d2
I have a similar issue and I have come to the conclusion that it is the rear glass panel. Unlike the front panel, the rear only rests on its own moving arms which allow some play. It vibrates when driving over rough surfaces and causes annoying noises.
A lot of people have solved this by adjusting the panel, but I believe there is a more permanent solution:
BMW ETK
Look for part numbers 54 34 7278097 and 54 34 7278098. These are buffers for the rear panel, which in my case are nowhere present. I believe BMW must have issued them later as a remedy to the vibration issues, but cannot be sure about it. Check to see if you have any rubber buffers where the panel can rest upon when closed... If not then these may be of help.
(I am in the process of acquiring those myself)
Old Jul 17, 2012 | 06:24 AM
walk0080's Avatar
walk0080
Old Jul 17, 2012 | 10:05 PM
alexs3d2's Avatar
alexs3d2
walk0080 could you take some pics of these metal/rubber stops? I would really like to know where exactly they are positioned to know if they can help my situation at all...
I think the rattles can be stopped with some panel adjustment, but the problem is how to get it done properly.
Old Jul 18, 2012 | 08:26 PM
walk0080's Avatar
walk0080
Old Jul 18, 2012 | 09:50 PM
alexs3d2's Avatar
alexs3d2
Thanks a lot! Definitely missing those, which I hope help my case
Old Jul 19, 2012 | 09:44 AM
DogT's Avatar
DogT
Ours not only leaked air but rattled right from the get go. I told the OL to have it fixed under warranty, but as usual she procrastinated until it was out of warranty and then it cost about $250 to have it adjusted. She's like that, loves to keep the money flowing.
ian260
Mar 29, 2017 06:08 AM
torpeau
Oct 8, 2015 11:10 AM
Jim Ferrell
Oct 6, 2015 08:09 AM
eliseo1981
Sep 30, 2015 07:57 PM
patsum
Sep 30, 2015 02:10 PM
