R56 Brake Light on
Old Jul 7, 2012 | 05:16 PM
PParker74's Avatar
PParker74
Brake Light on
The other day I was driving and the light with the mini on the what looks to be a lift illuminated along with the brake light on the tach. Can someone please tell me what this means, thanks
Old Jul 7, 2012 | 06:48 PM
05r50's Avatar
05r50
Normally that is an indication that you have tripped one of the brake wear sensors indicating that you need service.
Since your sig states you have a 2010 I am assuming you are under warranty. Take it to the dealer.
If you want to get more info, you can press the button on the turn signal lever and go into info mode. Press and hold until the service-info comes up. Release and press again. It should show you a picture of either the front half or rear half of the car and that lets you know which sensor you tripped.
Old Jul 7, 2012 | 07:08 PM
slinger688's Avatar
slinger688
Did it stay on?
Old Jul 8, 2012 | 03:24 AM
PParker74's Avatar
PParker74
It did say on. I finally located my owners manual, and it states an electrical failure. So I made a appointment to take it to Mini.
Old Jul 9, 2012 | 04:06 AM
PParker74's Avatar
PParker74
After some searching on this grate forum I discovered how to retrieve the service messages, and it has indicated the rear brakes. Unfortunately my 36000 mile service warranty is long over. I've order new pads and brake ware sensors and will tackel the brake job when I receive the parts.
Old Jul 16, 2012 | 07:05 AM
myR56S's Avatar
myR56S
I was under the impression 'newer' Mini's had 4yr/50k mi warranties(?). My 08 just fell out of warranty this last June.
Random thought: Are you really hard on brakes?
Ironically enough, my yellow brake light came on last night, after snooping through the service menu I found that my rear brakes flagged the light (42k mi).
Old Jul 17, 2012 | 06:16 AM
schatzy62's Avatar
schatzy62
Yes they do have a 4yr/50K mile "WARRANTY" but the "MAINTENANCE" plan which covers wear items is only good for 36K Miles.
Old Jul 17, 2012 | 06:41 AM
myR56S's Avatar
myR56S
Holy crap. Please excuse my ignorance, I did not read your post entirely and replied. You are correct. I will shut up now
theblackfalcon
Oct 11, 2015 09:49 AM
Powershift
Aug 16, 2015 05:14 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
