R50/53 Smell????
Old Jul 7, 2012 | 12:27 PM
DVS DEA's Avatar
DVS DEA
Smell????
After I floor it for some spirited passing there is a weird smell. Is this normal?
Old Jul 7, 2012 | 12:34 PM
joe_bfstplk's Avatar
joe_bfstplk
What sort of smell?
Old Jul 7, 2012 | 12:53 PM
DailyDrivenMini's Avatar
DailyDrivenMini
https://www.northamericanmotoring.co...n-cockpit.html
Old Jul 7, 2012 | 06:23 PM
DVS DEA's Avatar
DVS DEA
Dont think it is the exhaust.
The smell is just a smell that appears after hard accelaration.
Old Jul 7, 2012 | 06:40 PM
Braminator's Avatar
Braminator
Hard accelerating or hard driving( gas,brake turn etc.. fast)?
Old Jul 7, 2012 | 07:38 PM
Fly'n Brick's Avatar
Fly'n Brick
Does this occur with or without a passenger?
Old Jul 7, 2012 | 08:23 PM
ERIK06MCS's Avatar
ERIK06MCS
Ha flyin brick thats good stuff.
I would bet that everything just gets piping red hot under hard accel and you're just smelling the cat cookin or any type of corrosion resistant oils on the cat-bacm exhaust burning up.
Anyone thats ever replaced a catalytic converter can atest to the fact that on the first heat cycle production oils etc burn off as the exhaust/cat heat. So long as you have a catalytic converter your exhaust itself should be prettu odorless. This is why I would suspect you're just smelling normal burnoffs.
One last thing, check the condition of your belt, make sure its not glazed or smoking. Also, if your engine bay was ever detailed there will be plenty of shiny grease crap to burn off as the engine bay gets hot.
Old Jul 7, 2012 | 09:52 PM
SoundMessage's Avatar
SoundMessage
Had this in my Clubman...not quite an engine smell, not quite a fart smell, but just a "not quite right" smell after hard acceleration. Had my cabin air filter replaced. Smell gone.
Old Jul 7, 2012 | 10:01 PM
joe_bfstplk
A musty basement smell, perhaps? The a/c has a cut-off on full-throttle acceleration that would cause it to warm up a tad, possibly triggering the musty a/c smell.
My car's a/c smells just like my grandparents' basement when the a/c isn't fully cold.
HTH!
C ya,
Dutch
Old Jul 8, 2012 | 02:08 AM
DVS DEA's Avatar
DVS DEA
I think it is just burn off. But thanks for the response everyone.
Old Jul 8, 2012 | 03:31 AM
minsanity's Avatar
minsanity
Just make sure it isn't the smell of burnt rubber. That might be your crank pulley going.
Old Jul 8, 2012 | 07:47 AM
ZippyNH's Avatar
ZippyNH
Depends on the smell...
Smell like brakes.....then it might be a clutch starting to slip...
or burnt oils...just hot surfaces with oil blown back, getting cooked off....
But without quantifying the smell....kinda like saying i hear a noise...
Old Jul 8, 2012 | 08:21 AM
Aspen's Avatar
Aspen
Slipping belt, I had a smell that went after I changed it. Was noticeable in the vert. after flooring it with the top down.
Old Jul 8, 2012 | 08:05 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
To throw another into the mix,
Coolant boiling over from the expansion tank - bad cap
Had that problem for years until I bought a new cap.
Old Jul 8, 2012 | 09:50 PM
DVS DEA's Avatar
DVS DEA
Yeah i hear ya. But dont know what any of the other things smell lik .
Like saying " did the noise sound like a wombat in heat" but i never heard a wombat in heat before lol .
Just wonder if anyone else noticex an extra/stronger smell after flooring it. The smell goes away after a few minutes of regular driving.
Old Jul 8, 2012 | 11:17 PM
clay44's Avatar
clay44
Won't help you out but recently i had a bad smell in my car. Found a half eaten apple pie in a 7-11 bag that someone had decided to store under my passenger seat the week before.
Old Jul 9, 2012 | 07:21 AM
Fly'n Brick
I'd just about given up trying to find more ways to you-afy my MINI, make it way more than unique than anybody else. Trumped again.
Old Jul 9, 2012 | 01:39 PM
astroBlackMetallic_Mini's Avatar
HTH!
C ya,
Dutch
... pull out your Ac filter (under the glove box), vacuum and Febreeze it! that should take care of that smell... (i had similar, filter was covered in crap)
Old Jul 9, 2012 | 02:00 PM
squonk's Avatar
squonk
I have the same problem with my 2011 Clubman S with 11,000 miles on it. I find it hard to believe that the AC filter would be the culprit on a car 1.5 years old. And the smell is definitely related to hard acceleration only. I typically shift around 4000-5000 with moderate throttle. If I give it full throttle and shift beyond 5000, el stinko.
Old Jul 9, 2012 | 03:37 PM
Gizmo's Avatar
Gizmo
This x1,000,000 ^
Old Jul 9, 2012 | 04:47 PM
joe_bfstplk
I pulled it out and left it out, and it still makes that smell. I think it's the a/c coil itself being damp until enough air blows through it to dry it off.
C ya,
Dutch
Old Jul 9, 2012 | 05:47 PM
Fly'n Brick
You gotta be as old as the same dirt I am. Dang few people walking the earth today would have a clue as to who joe_bfstplk is. We've all got our little clouds to cower under don't we.
Old Jul 9, 2012 | 06:04 PM
joe_bfstplk
Probably not as old as you think. I'm early Gen-X, but grew up in a somewhat backwater area surrounded by old and abandoned poultry and dairy farms (and nearly on the cover of Led Zeppelin I, FWIW--Oh, the humanity!). As a result, I track more late-Boomer for my musical tastes and media exposure and don't really fit in either group well.
The fact that few remember that name makes it a great for signing up for online accounts....
So is your screen name in reference to the comment in "Space Cowboys"?
C ya,
Dutch
Old Jul 9, 2012 | 06:49 PM
Fly'n Brick
C ya,
Dutch
It's taken from what we called an old Austin Mini in a sports car club I once belonged to back in the '60s. We were inspired to name it that based on it's dexterity negotiating the cones.
Old Jul 9, 2012 | 07:52 PM
joe_bfstplk
Ak, k. You might enjoy "Space Cowboys", in any case, if you haven't seen it.
C ya,
Dutch
USA-RET
Jun 14, 2024 01:56 PM
drrigg
May 27, 2022 03:31 AM
mini_mike237
Sep 21, 2015 08:42 AM
Sep 2, 2015 09:05 AM
PParker74
R55 :: Clubman Talk (2008+)
Aug 30, 2015 04:20 PM
