R50/53 Speedometer mod
Old Jun 30, 2012 | 09:14 AM
swdsc's Avatar
swdsc
Speedometer mod
Is it possible to switch my 2005 speedometer with the new mini speedometers with the screen?
Old Jun 30, 2012 | 09:19 AM
clay44's Avatar
clay44
It probably is possible but i bet it's more money and work than it's worth.
Old Jun 30, 2012 | 09:35 AM
swdsc's Avatar
swdsc
i could go to my local junk yard they always have new car coming in to take parts off so money wont be that big of an issue but work yes.
Old Jun 30, 2012 | 09:50 AM
gerry2153's Avatar
gerry2153
good luck on that...
might not even be the same exact size as yours
and might not be as easy to find as you think
Im sure that its not plug and play
so you probably have to have the brain reprogrammed
may not even be possible
but if you do let us know how it works
Old Jun 30, 2012 | 10:50 AM
swdsc's Avatar
swdsc
i will once i find more info
Old Jun 30, 2012 | 11:20 AM
LethalR53's Avatar
LethalR53
Certainly sounds like an intesting idea.
Old Jun 30, 2012 | 12:00 PM
SHORT CIRCUIT's Avatar
SHORT CIRCUIT
The sizes are different. So you would have to do a dash swap, and the electrical would probably not work.
Old Jun 30, 2012 | 12:37 PM
rkw's Avatar
rkw
Not possible. Your car electronics are completely incompatible with newer models.
Old Jun 30, 2012 | 02:07 PM
MINIdave's Avatar
MINIdave
If you're trying to use one out of a 2nd gen car, then no.
If you're trying to get the nav screen out of a 1st gen car, then maybe - at least it will fit, and there will be some programming involved = $$$$
What exactly are you trying to do?
Are you trying to get MINI Connected, or Nav or what?
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
GAT
Oct 4, 2015 07:27 PM
eMINI of the State
Oct 2, 2015 03:12 PM
B1mm3r101
Oct 1, 2015 06:22 AM
WhinyR53
Sep 30, 2015 07:36 AM
