R56 Mystery hose dripping...
Old Feb 17, 2012 | 04:27 PM
surfin'02's Avatar
surfin'02
Hey Gang,
Got a curious question. The last few mornings I have noticed a puddle of water under my car. Taste-test does not detect antifreeze or any other unpleasent tastes.
Got my 2007 MCS up on ramps and found the source to be an oblong tube protruding through the exhaust heat shields approx. 2 feet from the rear of the engine compartment (roughly in the center in the pic).
Any idea what this is for and should it be dripping?
Old Feb 17, 2012 | 04:41 PM
mini4tide's Avatar
mini4tide
Coolant overflow release I would guess. If you over fill, it blows excess out there.
Old Feb 17, 2012 | 06:58 PM
JeffreyC's Avatar
JeffreyC
My vote is for the AC condensation tube.
Old Feb 17, 2012 | 08:04 PM
Benibiker's Avatar
Benibiker
I agree
Old Feb 17, 2012 | 08:24 PM
ricbow's Avatar
ricbow
It is the ac.
Old Feb 17, 2012 | 08:42 PM
Stanislaus's Avatar
Stanislaus
When it comes to automotive fluids, "taste tests" are a no-no.
Old Feb 18, 2012 | 05:14 AM
richardsperry's Avatar
richardsperry
Ehhh, a little bit won't hurt you... There isn't anything that's really poisonous.
Old Feb 18, 2012 | 05:25 AM
Herleman's Avatar
Herleman
Isn't there a drain tube for the sunroof guttering down there in that area?
Old Feb 18, 2012 | 06:08 AM
drsimmons's Avatar
drsimmons
If it's clear I'd agree with the A/C, if blueish I'd say coolant.
No taste so most likely A/C condensation.
Old Feb 18, 2012 | 02:41 PM
mini4tide's Avatar
mini4tide
Maybe I just assumed coolant because coolant is pouring out from my car everywher right now! Damn plastic thermostat!
Old Feb 18, 2012 | 02:49 PM
drsimmons's Avatar
drsimmons
I'd pull my car up on ramps and check it out except it's pouring outside. I have a metal carport but it's still wet.
Maybe tomorrow then I can try and trace the line.
Of course it's not cold enough to run the AC and I already had my thermostat replaced so I don't have coolant leaking or AC condensation.
Be interesting if someone figures out exactly what it is.
Old Feb 18, 2012 | 04:51 PM
surfin'02's Avatar
surfin'02
Thanks everyone for your feedback...liquid dripping was clear, not blue.
Old Feb 18, 2012 | 05:37 PM
MINIdave's Avatar
MINIdave
Where are you located?
Has it been over 40* there?
Do you have a sunroof?
Has it rained lately?
Old Feb 18, 2012 | 06:07 PM
Benibiker's Avatar
Benibiker
You can probably see it by opening the hood and looking at the passenger area, between the engine and the firewall. It's the a/c dripping for sure. The radiator overfill and reservoir are located towards the front of the engine on the driver's side.
Old Feb 19, 2012 | 05:28 AM
trakatdave's Avatar
trakatdave
If you operated the window defrost the AC would operate.
Old Feb 19, 2012 | 06:22 AM
ricbow's Avatar
ricbow
it **** with my head too
Old Feb 19, 2012 | 06:46 PM
Hoof hearted's Avatar
Hoof hearted
My vote is for the condenser drain tube as well. When it dries up outside drive around without AC or defrost and see if it is dripping anymore.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
gar56
Nov 15, 2016 06:41 AM
vulkandino
Oct 31, 2015 08:29 PM
GAT
Oct 4, 2015 07:27 PM
eMINI of the State
Oct 2, 2015 03:12 PM
