Door open warning light
Old Jan 14, 2012 | 04:38 AM
GoThingNC's Avatar
GoThingNC
2nd day have the Mini and this morning I noticed that the open door/hatch light decided to stay on.
So the sensors sometimes get sticky when it is cold out?
Other than that everything else is fine.
Old Jan 14, 2012 | 10:55 AM
GoThingNC's Avatar
GoThingNC
Problem solved
Got home, opened the rear hatch and stuck my finger into the release catch (or whatever it is called) and wiggled it around a bit.
The light now turns off.
Old Jul 10, 2022 | 10:54 AM
atombaum's Avatar
atombaum
2015 mini countryman door open warning light
  • 2015 Countryman "S" with 80k miles.
  • Weather conditions (per moisture content conversations): It's July 10, temperature is 75 degrees, low humidity, sunny skies, no rain for the last week. i.e. unlikely water or moisture got into the sensor connection.
  • The problem just started today. Stopped the car twice along the road, and checked/closed all the doors tight.
  • The warning indicated it was coming from the right side of the car.
  • Got home, and the only thing I did was to spray WD-40 (in and/or around) all the door hinges, and latch mechanisms (including engine hood, and rear hatch).
  • Then came inside to check this forum for possible solutions.
  • Just read the previous post about jiggling the door latch mechanisms, but as soon as I backed out of the garage to try it, and drove forward (to reach 2-3 mph when the light comes on) the problem was solved.
  • Washed car in celebration.
  • I know it will happen again, but all is well for now.
Clubmaste00
R55 :: Clubman Talk (2008+)
Feb 10, 2018 06:43 PM
flee
12
Sep 19, 2013 10:30 PM
peekinde
Jul 20, 2007 01:15 PM
boxerboy43
Nov 11, 2006 04:19 PM
c615586
Aug 11, 2005 10:05 PM
