clock and trip odometer zeroed out?!?
Old Jan 10, 2012 | 01:17 PM
krishnika's Avatar
krishnika
Last week I noticed that the clock started showing just dashes and the trip odometer had restarted at zero. (Messed up my gas mileage records, oh well) Can't figure out what happened. I reset the clock and haven't had an issues with it since, but would like to know if there is an electrical issue that I should get checked out by a shop. Has this happened to anyone else? I'm assuming it's not a big deal, but would like some reassurance from someone knowledgeable and also any tips for making sure it doesn't happen again. thanks.
Old Jan 12, 2012 | 11:07 AM
krishnika's Avatar
krishnika
I know this is a small thing compared to the other posts, but anyone have a comment? thanks.
Old Jan 12, 2012 | 11:59 AM
yetti96's Avatar
yetti96
Battery might be going?
Old Jan 12, 2012 | 02:43 PM
Capt_bj's Avatar
Capt_bj
yep - that's my first guess
I'm thinking a borderline battery, while cranking the starter, sent 0 to the clock and OBC long enuf for everything to zero out . . .
how old is your battery? MINI battery does not die gracefully. One time you get a start, next time you don't. You do not experience a 'slow crank'.
If the battery is 5 years old I'd replace it . . .
Old Jan 13, 2012 | 07:27 AM
krishnika's Avatar
krishnika
Yes, I've got the original battery in, so 5 years old. Can any auto shop order one for me? thanks so much.
Old Jan 13, 2012 | 07:39 AM
JumpingJackFlash's Avatar
JumpingJackFlash
Everstart MAXX 47-3 at Walmart. Last I checked, it was $90. It may come with dual vent tubes. Since you have a non-S, I don't know if you have ventilation in the battery box (since it's in the front). If so, make sure both ends are capped off. You can get a small package of rubber caps at Walmart or any other parts store.
Old Jan 13, 2012 | 07:58 AM
krishnika's Avatar
krishnika
wow, thanks, but I truly have no clue how to do something like that myself. I suppose I could buy one and take it to a shop?
Old Jan 13, 2012 | 08:21 AM
Capt_bj's Avatar
Capt_bj
most major part places like AutoZone or PepBoys will have a suitable battery in stock and will install it for free.
Old Jan 13, 2012 | 08:24 AM
JumpingJackFlash
+1 to auto parts store assisting you. Autozone wanted $135 for a new battery (compared to $90 for Walmart). Check around to find out if Advance or Pep Boys will charge less.
Old Jan 13, 2012 | 09:28 AM
krishnika's Avatar
krishnika
I feel like I should have known this kind of basic stuff already. thanks so much for the help - very much appreciated!
Old Jan 13, 2012 | 10:16 AM
yetti96's Avatar
yetti96
Gotta learn somehow and sometime. Parts stores will usually test the battery too and confirm the old one is dieing.
madmix
Oct 5, 2015 09:58 AM
MINI Stupor
Oct 1, 2015 11:36 AM
kevinlhr310
Sep 27, 2015 02:31 PM
daviday
Sep 25, 2015 01:31 AM
wyliec0y0te
Sep 15, 2015 01:13 PM
