R56 R56 +35mm offset wheels question...
Old Nov 14, 2011 | 03:28 AM
mini4tide's Avatar
mini4tide
Anybody running 18x8 +35mm offset wheels? Or any size with +35 offset for that matter? Any issues? Thanks
Old Nov 14, 2011 | 03:39 AM
OZChris's Avatar
OZChris
18x8 ET38 and a 5mm spacer on the front.
http://www.motoringunderground.com/f...8&postcount=94
Old Nov 14, 2011 | 04:12 AM
mini4tide's Avatar
mini4tide
Wow, looks great! I'm thinking +35 will stick out if thats +38 and flush...
Old Nov 14, 2011 | 09:25 AM
Bigprfed22's Avatar
Bigprfed22
technically im running +33 and that clears on a 17 by about 1-2mm's
Old Nov 14, 2011 | 11:28 AM
accesstd's Avatar
accesstd
18x8 with +35 offset wheels
Which wheels are you looking at getting with those specs. The reason I'm asking is because my wheels have those EXACT specs. I'm running a set of MSR 045 wheels that are 18x8 with a +35 offset. I've got them wrapped with Goodyear F1's: 225/35/18. I'm also sitting on a set of H&R sport springs. I have absolutely no problems with rubbing (except when I "bottom-out" on big dips). My setup BARELY pokes out from the fenders. I'm totally happy with the setup.
Old Nov 14, 2011 | 12:45 PM
Boosted_Mini's Avatar
Boosted_Mini
I am on 17x7.5 +35MM.
I dont have issues and I run a 225/45/17 - so +20MM wider than stock and am on lowering springs and I do not rub.
http://i14.photobucket.com/albums/a3...-08-08_207.jpg
Old Nov 14, 2011 | 02:42 PM
mini4tide's Avatar
mini4tide
Well, funny you ask. I'm looking at the MSR 045 and the Exel TZ-10 18x8 +35 on both. Can you post a photo of how much they poke past the fenders. Im lowered, but not too low. Thanks
Old Nov 14, 2011 | 02:47 PM
mini4tide's Avatar
mini4tide
Just found out the whole Exel line is discontinued, so the MSRs are looking like my wheel.
Old Nov 14, 2011 | 04:33 PM
mini4tide's Avatar
mini4tide
That looks great!
Old Nov 14, 2011 | 05:07 PM
Boosted_Mini
Originally Posted by mini4tide
That looks great!
Thank you
Old Nov 16, 2011 | 02:25 PM
accesstd's Avatar
accesstd
Here are some pics of my setup. I hope this helps. Btw, I love my wheels. I was actually surprised that I was able to fit the 225/35/18 on and not have any rubbing issues, especially when turning lock-to-lock.
Old Nov 16, 2011 | 02:34 PM
accesstd's Avatar
accesstd
oh, btw, sorry for the filthy car. I quietly hang my head in shame for not keeping my mini in better condition. ;-) It actually looks better when she's clean -- as do the wheels.
Old Nov 16, 2011 | 04:16 PM
mini4tide's Avatar
mini4tide
^ Me like!!! Looks like 18x8 +35 it is! Thanks!!!!
Old Nov 16, 2011 | 09:04 PM
accesstd's Avatar
accesstd
Just a quick note, and I'm not just saying thing because it's my car, but that stance with the wider rubber (225/35/18) is definitely sweet. My original tires were 205/40/18 and they were stretched on the 18x8s. If you decide on this wheel setup, don't let the wheel shop tell you that you can't go wider -- because you can and it looks a heck of a lot better than the 205s. Don't go anything less than 215s. You WILL BE DISAPPOINTED. I was. Good luck and be sure to post pics after you get your wheels mounted.
Old Nov 16, 2011 | 10:11 PM
Boosted_Mini
Surprised you still have that much wheel gap with the H&Rs.
Old Nov 17, 2011 | 02:25 PM
accesstd's Avatar
accesstd
Yeah, it's the only annoying thing about the H&R setup. The back end is higher than the front. I have an alta rear sway bar set at the hardest setting, but that doesn't make a difference in height. I wish the rear sat as low as the front.
You should have seen it before the springs- 4x4 mini. Before the springs, the wheels actually looked way too big for the car. It looked like one of those ghetto @ss caddy's rollin on 24s.
I'm happy with the H&Rs for now. I may drop the $$ and get some coil overs later on down the road. But there are many other important mods I'll be purchasing before I worry about dropping my car another 1". And if I do, one day, switch to coil overs, I think I'll be changing out the wheels too and drop back down to some 17s.
Old Nov 17, 2011 | 03:45 PM
Boosted_Mini
I only say that cause I am on H&R springs and my car seems to have less wheel gap then that if you go up a little in the thread i linked a pic of my car and I seem to be about 1/2" to 1" lower.
And I am not trying to be rude just comparing setups so please dont take it that way.
Old Nov 18, 2011 | 08:41 AM
accesstd's Avatar
accesstd
Oh, by all means, no offense taken in any way. I totally agree with you. I think another thing that increased my wheel gap is when I switched to the 225/35s from my original 205/40/18s. My new tires are a lot thinner. I thought about going with 225/40/18, but when I stood those next to the 205/40/18s they were significantly taller. I figured I would play it safe and go with the lower profiles. My biggest concern was the wider tires rubbing in the front when I turned full lock.
SosoMINI
Nov 22, 2015 03:17 PM
StuRat
Aug 24, 2015 06:24 PM
Mini'mon
Aug 16, 2015 04:15 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
