R56 Help with brake squealing !
Old Nov 11, 2011 | 08:28 PM
Powashiftin's Avatar
Powashiftin
Just had new centric rotors, ebc red stuff pads, stainless steel lines and fluid changed. I'm hearing a crazy squeal from the brakes. I didn't get new sensors. Could that be it? If not, what could it be??
Help!
Old Nov 11, 2011 | 11:34 PM
proximo's Avatar
proximo
Brake squealing is generally caused by two metal pieces rubbing together. I would look to see that the brake pads had brake grease applied between it and the caliper (every spot the brake pad touches the caliper -- both pads per brake). Vibrations in the braking process cause this.
The sensors will not cause this.
Old Nov 12, 2011 | 12:58 AM
cccplus's Avatar
cccplus
did you 'bed' in the new brakes properly?
Old Nov 12, 2011 | 02:50 AM
HRM's Avatar
HRM
Have you driven them 1000 miles? IIRC EBC has statement with the pads saying they will not even talk to you about noisy pads until they are bed in, which they say may take that long to bed in.(depending on driving)
http://www.ebcbrakes.com/typicalq&a.shtml
3. Brake Squeal - Automotive Only!
Brake squeal often happens during the first few hundred miles of use as pads bed in to a new or used rotor. Provided that you have the latest engineering specification of pad with center line slots, edge chamfers and black noise reduction shims on the reverse of the pads, please wait until you have achieved 1000 miles of driving before evaluating brake noise. If you have EBC Brake pads that do not have these shims, and are located in mainland USA we will post these to you free of charge. In early production some EBC REAR fitment pads did not have noise shims. We offer to mail these free of charge if you have rear brake noise which is the most common. Rear brake noise can develop even when rear pads have NOT been changed as the more efficient front pads take up all the brake load and leave the original rear pads under-utilised. This will necessitate changing the rear pads to the same pads as in the front or if the original rears are also non shimmed, you may be able to solve with adding shims to those. Ask us for a free set of shims for those pads which we are happy to supply at no charge. It is quite common with performance pads to hear a once only screech when REVERSING from a cold start. This is because of the change in geometry of pad and rotor alignment in reverse motion. When driving forward the noise should not repeat.
http://www.ebcbrakes.com/automotive/...ds/index.shtml
Old Nov 12, 2011 | 04:42 AM
drewstermalloy's Avatar
drewstermalloy
Do you have a JCW?
Old Nov 12, 2011 | 08:31 AM
Porthos's Avatar
Porthos
+1 million that is exactly how redstuff acts and it takes around that long for them to quiet down.
OP your fine it will go away.
Old Nov 13, 2011 | 08:41 AM
Powashiftin
Thanks guys! Braking is fantastic with this setup. I've only driven about 200 miles. I haven't "bed" in the brakes yet. I'm waiting until 500 miles with the new setup. Still hear a lot of what I'd say is "metal on metal" squealing.
Old Nov 13, 2011 | 09:35 AM
Capt_bj's Avatar
Capt_bj
EBC uses a special 'break in coating' - until you burn thru that you aren't even to the 'real stuff' yet.
Old Nov 13, 2011 | 04:01 PM
NJ Mini's Avatar
NJ Mini
The EBC's will squeal, but not terribly so. If you've driven on them for any period, you should go bed them in and see if they still squeal. The longer you wait, the less likely EBC will replace them. I had some issues with a set of Red Stuff pads I used on my previous car and their customer service was fantastic and replaced them right away once it was reported within the first few hundred miles.
Also, just a side note, but worth quickly having a look at...a lot of shops don't realize that the EBC's come with a shim (it's black) already on the pad and will often put another one on top. This would cause a metal on metal surface and could cause the squealing you hear. Otherwise, as someone mentioned above, there might not be enough grease on the pad backing.
lweaver
Sep 17, 2024 08:22 AM
Casrio
Apr 20, 2021 01:52 AM
Sep 10, 2015 10:52 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
