R50/53 Runs long enough to get out of driveway then limp mode
Old Aug 24, 2011 | 02:39 PM
JoelDB44's Avatar
JoelDB44
I have a 2005 S with 87k miles. 3 times in the Texas heat, it has died, then re-started 20-30 minutes later. The last time it stayed in limp mode long enough to get home. I've checked the water, checked the cooling fan by turning the engine and AC on, in Park, and watching for the fan to come on. It does.
I can start it, and get out of my driveway halfway down the street when the Check engine light comes on and it goes into limp mode.
Trying to diagnose it. Any ideas?
Old Aug 24, 2011 | 02:52 PM
carramrod's Avatar
carramrod
Can you limp to an AutoZone or Advanced and get the code checked? That would be my first step.
Old Aug 24, 2011 | 03:02 PM
JoelDB44's Avatar
JoelDB44
Probably, although the light has been intermittently on before and Auto Zone checked but could not get a reading. There is now a squealing that is coming from the left side (passenger side) of the engine, but it goes away after I get out of the driveway. I'll try to get it to Auto Zone
Old Aug 24, 2011 | 03:06 PM
carramrod's Avatar
carramrod
Squealing sounds like a belt issue. I'd visually check the belt, make sure it's not frayed or anything.
Old Aug 24, 2011 | 05:45 PM
HyperBlueSTX20's Avatar
HyperBlueSTX20
Sounds very familiar to my 05 S with 86k miles that recently broke it's harmonic balancer. The pully part of the ballancer seperated from the section that bolts to the crank. It would free spin. Just something to look into, see if your belt is spinning.
Old Aug 24, 2011 | 07:33 PM
ZippyNH's Avatar
ZippyNH
Sounds like you have 2 issues....
the squeezing belt is usually a seperate issue....and another issue...
Could be anything...you needs the codes...if it goes into limp mode, the computer has determined something is seriously wrong...and has gone to safe mode/limp mode....good enough to get off the road, maybe home or a repair shop.
Could be anything from a sensor to a major mechanical issue...
Just remember if the code says "x reading out of limits on y sensor", that sensor may/magnitude be good...it could be something else broken causing the bad numbers...so don't let the auto place sell you a bag of parts without first testing the sensor first....
For most folks, go to a shop...
Old Aug 24, 2011 | 07:46 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Sounds like you have a crank pulley coming apart. Replace it with an ATI damper so it doesn't happen again. Use a prybar on the crank pulley and see if it moves, if it does replace it ASAP.
Old Aug 25, 2011 | 05:58 PM
JoelDB44's Avatar
JoelDB44
Tried to sneak out to auto zone, but it went in to limp mode and I smelled something like burning rubber so limped back to the garage. Jacked it up, pulled the inner fender and pried on the crank pulley. The part that the belt touches slides on the part that bolts to the crank. So that sounds like a crank pulley replacement, right?
Old Aug 25, 2011 | 07:04 PM
HyperBlueSTX20
Yep crank pulley, do what Way said get the ATI, that is what I did.
Getrieben
Sep 12, 2024 07:03 AM
Getrieben
Aug 17, 2016 06:32 AM
theblackfalcon
Oct 11, 2015 09:49 AM
Dsinkster
Aug 17, 2015 03:24 PM
elightbo
Aug 17, 2015 01:50 PM
