Suspension help to decide suspension options
Old Apr 10, 2011 | 05:06 PM
GPToyz's Avatar
GPToyz
I'm trying to keep my mcs on sort of a controlled budget. I spend the coin and buy the unobtanium on my racebikes
My 2 options for my budget are:
Megan Street Coilovers - $844.06 shipped
Koni Sport Suspension kit - $667 plus shipping
I'm leaning towards the megans because:
they are ride height, rebound and compression adjustable - which would be great for corner balancing. Also they come with an adjustable camber plates. and later on, if i wanted to I could upgrade to swift springs.
what holds me back on the megans is the overall build quality - basically I don't want to have to rebuild the suspension every year!
The koni kit is cheaper and I'm sure comes with koni quality but is only adjustable in terms of a single **** adjuster for "soft" or "firm" - basically I can't screw it up and its easy as cake and I can be lazy.
I do 90% street driving with occasional track days for fun.
Old Apr 10, 2011 | 05:35 PM
luseboy's Avatar
luseboy
Personally, i plan on going with megans. I think it depends on whether or not you want to lower your car a lot, or just a little.
-Austin
Old Apr 10, 2011 | 06:04 PM
Vollgas's Avatar
Vollgas
I have the Koni Sprt Suspension on my car.
To me, it is the best suspension out there.
The ride and comfort on the car is perfect.
The spring rates are dead on.
If you want to waste money on coilovers you can.
Most people would not feel a change in rebound or compression damping if you gave them a book.
The only thing coilovers have is ride height.
The Koni's do drop a little ride height.
Old Apr 10, 2011 | 07:33 PM
GPToyz's Avatar
GPToyz
Well my goal is to be able to corner balance - and to accomplish that the suspension needs to be able to adjust ride height.
As far as lowering that's not my goal - I actually think the ride height is fine
Good to know feedback.
Old Apr 11, 2011 | 09:00 PM
crosmodmini's Avatar
crosmodmini
What do you thinks about the BC coilovers?
Old Apr 11, 2011 | 09:13 PM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
Get the KONI's, quality, and durrability mean more than a corner balance on a DD street car.
Just an FYI, a 5psi differance in tire pressure can throw off a corner balance, your tires can change that mutch between hot and cold.
Old Apr 12, 2011 | 08:30 AM
TylerF's Avatar
TylerF
I really like my Megans, but just to clarify, there is only one adjustment **** on them. It controls the rebound and compression circuits together. Even so, I like mine.
Old Apr 13, 2011 | 09:06 AM
broadwayline's Avatar
broadwayline
I would not expect a large handling increase with Megans, the dampers are quite poor quality.
Yes they have more 'adjustment' but if you look at a shock dyno of a pair you will see there is really only one area that works properly in the entire adjustment range.
If you want to lower your car on a budget they are great for that.
Old Apr 13, 2011 | 09:17 AM
rjtrout2000's Avatar
rjtrout2000
Koni Yellows and TSW springs FTW
Old Apr 13, 2011 | 02:15 PM
DICKS GARAGE R53
^^^ +2 ^^^ Its a proven, reliable setup with great handling charictoristics.
Old Apr 24, 2011 | 11:52 AM
MrCooperS's Avatar
MrCooperS
Moderator
What settings would you use in the Koni Yellow for spirited street driving?
Old Apr 24, 2011 | 01:26 PM
DICKS GARAGE R53
You would need to figgure that out for yourself, everybody's different. Just a suggestion though, the fronts most of the time end up going stiffer than the rears, for better results.
Old Apr 24, 2011 | 01:46 PM
MrCooperS's Avatar
MrCooperS
Moderator
Haha sounds good. I don't mind adjusting the fronts to dial it in. But I hear the rear is a pain to adjust.
Old Apr 24, 2011 | 06:41 PM
nopistons's Avatar
nopistons
Yeah, you need to take the shocks out of the car to adjust the rears. I have my rears set right in the middle and the fronts slightly stiffer than middle.
Just a quick side question, does one have to get a rear wheel alignment when removing the rear shocks to adjust them? I dont think so, but I'd thought I ask...
Old Apr 24, 2011 | 06:50 PM
MrCooperS's Avatar
MrCooperS
Moderator
Do you normally have to do a alignment when you upgrade springs/suspensions/coilovers?
Old Apr 24, 2011 | 07:17 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You really should to maximize your tire life, and get the best out of the suspension upgrade.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
ccccPUNISHER
Aug 20, 2015 09:02 PM
Emnotek
Aug 13, 2015 05:47 PM
fm.illuminatus
Aug 10, 2015 12:15 AM
