Navigation & Audio MINI Connected - Plugin Feature
Old Mar 21, 2011 | 12:21 PM
punkrockdoc's Avatar
punkrockdoc
I love the Plugin feature with my iPhone, since it provides an exact replica of the iPod classic menu system on the connected sceen, and is MUCH easier to navigate through than when accessing the iPhone through the External Devices menu option. However, the resolution on the sceen when I use the Plugin feature is noticably worse. Artwork that shows up crystal clear via the external device input is blurry and muddy through the plugin menu option. Has anyone else noticed this?
Old Mar 21, 2011 | 12:34 PM
siriuszero's Avatar
siriuszero
I've seen that on a demo CM...I would guess that it is a limitation of the iPhone/iPod/ix's Plugin feature rather than a fault of the Connected system itself.
Old Mar 22, 2011 | 09:41 AM
runlikeachicken's Avatar
runlikeachicken
I notice that the plug in function does not work with the 3GS iPhone. Is any one experiencing the same problem. My wife iPhone 4 work perfectly though.
Old Mar 22, 2011 | 10:23 AM
punkrockdoc
I figured that it was likely an output setting of the iPhone, although I don't think that there is anyway to change the resolution that it outputs. It's just a bit disapointing because many of the promotional videos and pictures seem to show a higher resolution. Of course, that's why they're promotional.
I'm surprised that it doesn't work with an iPhone 3GS. It utilizes the "iPod Out" feature of iOS 4. If the software on the 3GS is iOS 4, it should work.
Old Mar 22, 2011 | 10:52 AM
bspence88's Avatar
bspence88
I can't even get the plugin option on my MINI Connected?! Any suggestions? Is it cause I'm from Canada? :(
Old Mar 22, 2011 | 12:23 PM
runlikeachicken
Just check the version of the phone... Is 4.2.1 . Btw is jailbroken, maybe that could be a reason
Old Mar 22, 2011 | 04:18 PM
bspence88's Avatar
bspence88
It's 4.2.1, but it is jailbroken. Didn't think that would affect it.... shitty.
Old Mar 31, 2011 | 07:04 PM
bspence88's Avatar
bspence88
So I upgraded my iPhone to the latest firmware 4.3.1 and it is no longer jailbroken. But I still don't have a plugin feature.... any ideas?
Old Mar 31, 2011 | 08:13 PM
BikeisDusty's Avatar
BikeisDusty
Bspense88, Are you using the Mini Connected app and the AV cable? The cable needed is the AV cable which has a different AUX connector (has 4 rings). Are you able to do other connect features, like pandora, web radio, facebook and such? If not, you have the wrong cable or your app is not connecting. The connected app as to be running. or it does not work. If these are working, then look in the Connected menu and select plugin. If you are getting the Connected features, but no plugin, then you need to call Mini usa or your dealer.
I just got my mini with connect. The dealer gave me the wrong cable (ipod cable) and had to send me AV cable to get it to work right. The old cable would play audio from the phone (pandora and ipod), but would not do the connected features. New cable with the Connected App, works like a champ.
Old Mar 31, 2011 | 11:10 PM
bspence88's Avatar
bspence88
Thanks for the quick reply. I am able to access all other features like Facebook, Twitter, Google, etc. But the Plugin option just doesn't show up. I went to the dealer, and they weren't sure what was wrong either. Pretty much, no one knows. Unless it's a feature only available in US MINI's and not Canadian ones.
Old Mar 31, 2011 | 11:27 PM
siriuszero's Avatar
siriuszero
Hey bspence-
I just got my MINI with Connected so I've been futzing around with it too. The Connected app does not need to be running on the iPhone for PlugIn to work, but you do need the proper AV cable because the PlugIn interface is just the iPhone outputting it's own menu via video out. If you look at the Y cable that came with your MINI, the audio jack that goes into the car (the one that looks like a headphone plug) should have 3 black rings on it. If you just see two, you do not have the right cable.
Hope that helps. I'll bet you don't have the right cable...
Old Apr 1, 2011 | 03:54 AM
BikeisDusty
Bspense88, if you got the right cable, then I have no idea why it is not working.
Are you able to do the Pandora radio with cover flow or play a video? The video select is in the CD/media menu. This is assuming you can get to your ipod there. If these do not work, you may not have the right cable.
This thread has a pics of the cables.
https://www.northamericanmotoring.co...phone-4-a.html
Old May 29, 2011 | 05:35 AM
buckland's Avatar
buckland
Me too! I get a message that this connection is not optimized for this otion - or something like that. I have the cable the dealer gave me, but I'll check the pics from the other thread and see if I have the wrong one.
Buck
Old May 29, 2011 | 05:38 AM
buckland's Avatar
buckland
Accoring to the pics, I may have the "old" cable. I'll ask my dealer if the new one is available.
Buck
Old May 29, 2011 | 08:21 AM
SoCalledFriend's Avatar
SoCalledFriend
OK...I'm waiting on my car so bear with me. I just want to be prepared when I get it.
This is what I currently have;
120GB iPod Classic (about 1 1/2 yrs. old). I want to be able to use this primarily and see the album artwork on the screen. What cable do I need for this to happen?
I also have an iPhone 3GS with IOS4. Can I use the same cable as the one for my iPod classic or will I need a "different" Y-Cable in order for the iPhone functionality (Connected App) to work?
Thanks in advance.
Old May 29, 2011 | 03:57 PM
SoCalledFriend
Thanks in advance.
Nevermind......I just went down to the dealership and demo'd both my iPhone (3GS w/ iOS4) and my iPod classic. Both work just fine with the cable that has the 3 rings at the end of the jack. The only difference between the two is that the album art on the iPod classic isn't as clear (worse resolution) as the album art on the iPhone, but the album art does appear on the screen for both.
Dec 23, 2015 10:36 AM
minicoclub
Aug 25, 2015 09:07 AM
noreen99
Aug 8, 2015 08:21 AM
tippin
Aug 5, 2015 08:43 AM
