R56 lug bolt
Old Feb 15, 2011 | 11:46 AM
kadaj's Avatar
kadaj
R56 lug bolt
my lug bolts are stripping a bit and im trying to look for new ones... my mini is an 2009 S and i was wondering if you guys can help me.... i have factory wheels..
thanks!
Old Feb 15, 2011 | 12:53 PM
Bigprfed22's Avatar
Bigprfed22
Are the lugs or hubs stripping? Dealer, lugs are cheap.
Old Feb 15, 2011 | 01:05 PM
kadaj's Avatar
kadaj
i think the lug and hob is only one piece
Old Feb 15, 2011 | 01:10 PM
Bigprfed22's Avatar
Bigprfed22
The hub is what you screw the lug in to, the lug is the part that goes through the wheel
Old Feb 15, 2011 | 01:19 PM
kadaj's Avatar
kadaj
Old Feb 15, 2011 | 01:22 PM
Eric_Rowland's Avatar
Eric_Rowland
If the threads of the lugs are distorted in any way, do yourself a favor and run the correct size tap in the hub before installing the new lugs. You might also want to try a dab of anti-seize on the new lugs. (note: using anti-seize technically alters the torque value)
Bigprfed22's Avatar
Bigprfed22
So is the bolt stripping or the hub? if its a bolt go purchase one from the dealer or order it, Not expenseive. If its the hub , same deal except its more expensive.
Old Feb 15, 2011 | 01:23 PM
Bigprfed22's Avatar
Bigprfed22
+1 on running a tap to clean the threads out
Old Feb 15, 2011 | 01:27 PM
kadaj's Avatar
kadaj
thankyou guys! ^^
Old Feb 18, 2011 | 08:12 AM
Himself's Avatar
Himself
If it's the lug bold just replace it. I would check the threads in the hub to verify the threads aren't damaged. If the hub is damaged, just get a tap and clean the threads. Make sure you use plenty of lubrication. It's interesting that they are stripping. Are you torquing your lugs down or just doing it by feel?
MyMiniS
Sep 18, 2021 05:58 AM
madmaxxed
Sep 2, 2015 03:32 PM
minibenworks
Aug 30, 2015 08:45 PM
minipopkart
Aug 13, 2015 05:22 AM
minipopkart
Aug 9, 2015 12:13 PM
