R50/53 MCS Sport Suspension Plus...Which Shocks?
Old Jan 11, 2011 | 04:46 PM
stuffedgus's Avatar
stuffedgus
Old Jan 11, 2011 | 05:36 PM
MINI33342's Avatar
MINI33342
Replace with the OEM or get all 4.....don't get just new aftermarket rears.
Old Jan 11, 2011 | 06:24 PM
Vollgas's Avatar
Vollgas
I would suggest you look at the Koni Sport Suspension (Yellow).
Great suspension.
Adjustable
Good ride
Old Jan 11, 2011 | 06:29 PM
stuffedgus's Avatar
stuffedgus
Old Jan 11, 2011 | 07:49 PM
veggivet's Avatar
veggivet
KONI FSD's are very popular as well. I have them on both of my MINI's and really like the ride and handling they provide.
Old Jan 12, 2011 | 07:42 AM
quikmni's Avatar
quikmni
For your planned use, I suggest Koni FSD.
Old Jan 12, 2011 | 11:02 AM
Checkmate_2006's Avatar
Checkmate_2006
Will the KONI's reduce the ride height at all?
Old Jan 12, 2011 | 11:13 AM
veggivet's Avatar
veggivet
They will, but only by about 1/4 to 1/3 inch.
Old Jan 12, 2011 | 11:16 AM
Project_2501's Avatar
Project_2501
The Koni FSD should not reduce your ride height at all, as they're typically designed as a stock replacement strut with better valving technology for better performance and comfort.
Koni Yellows (a standard in entry-level performance) have a slightly shorter strut body and piston, designed to be used with lowering springs. They are also valved stiffer for compression and rebound. This gives better handling and a willingness to be paired with stiffer springs that are also designed to lower the car. These should lower the car slightly when paired with stock springs, but not a lot. The real benefit is seen when paired with performance springs (or something like ground-control sleeves).
Old Jan 12, 2011 | 06:23 PM
stuffedgus's Avatar
stuffedgus
Old Jan 12, 2011 | 06:28 PM
veggivet's Avatar
veggivet
I know the FSD's shouldn't lower the car at all, but they did on both of my installs. Not enough to really change the geometry, though. There's a pretty long thread somewhere on this site about this exact question. Consensus was the amount of lowering I experienced.
SD200
Suspension
Jul 6, 2018 09:20 AM
Chino_0
Suspension
Mar 13, 2018 08:05 PM
k_h_d
Suspension
Oct 15, 2012 04:44 AM
ieandro
Jan 13, 2012 11:27 AM
steve216
Suspension
12
Jan 30, 2011 09:43 PM
