R56 lens change?
Old Dec 24, 2010 | 11:46 PM
Rob490's Avatar
Rob490
lens change?
Ive been searching through the forums and i cant get a decent answer to this question.
How do i change out/take out the Orange lens on my headlight. I really hate the egg yold and would love to get it out. Is baking my only option? Does the housing come off without baking? What do i do?
Old Dec 25, 2010 | 04:33 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
63122751875 - $299.00
63122751876 - $299.00
Buy new set of headlights from MINI with white indicators, sell the old ones ?
http://www.penskeparts.com/DiagramsM...0&rnd=03192010
Old Dec 25, 2010 | 05:51 AM
richardsperry's Avatar
richardsperry
Try $600 ea if you have Bixenon's..
Old Dec 25, 2010 | 08:03 AM
tvanhouten's Avatar
tvanhouten
Actully, there are a number of posts on this very issue (see links below). Seems like a trade off to buy new lights or follow the posts of how to change the lenses. Pay more for the lights and bolt in, or save money and DIY ???
https://www.northamericanmotoring.co...al-lenses.html
https://www.northamericanmotoring.co...or-lenses.html
https://www.northamericanmotoring.co...g-changes.html
tvanhouten
Old Dec 25, 2010 | 08:11 AM
Creeve's Avatar
Creeve
You can get the lenses out without baking the lights. You can't get new ones in though. Honestly I can't remember how I did it cause it was 3 yrs ago. But I know its possible.
Old Dec 26, 2010 | 07:11 AM
mini coop's Avatar
mini coop
DIY Clear Front Turn Signal Lenses...... in NAM. Actually four posts above this one in the sequential forum post list.
Old Dec 28, 2010 | 05:52 AM
yetti96's Avatar
yetti96
Baking is way easy. 200F and 5 minutes or so and remove the metal clip at the top, gently release the clips and use a couple or screw drivers or in my case a screwdriver and a 1" putty knife. Gently pry and release the two parts from each other in a few minutes before the sealant dries up.
Old Dec 28, 2010 | 12:01 PM
Rob490's Avatar
Rob490
I get that its not that hard. I just dont feel comfortable putting my car parts in an oven
Old Dec 28, 2010 | 12:14 PM
yetti96's Avatar
yetti96
I thought the same thing, so I did them one at a time and then dremeled a bunch out of the back and added projectors while it was apart and now I have somewhat OEM HIDs that don't glare.
Old Dec 28, 2010 | 05:15 PM
KevinC's Avatar
KevinC
Old Dec 28, 2010 | 06:02 PM
automan21's Avatar
automan21
Oh yeah, lets see some pics.
Old Dec 28, 2010 | 07:36 PM
68_steps's Avatar
68_steps
Well I personally did this Christmas day in about 10 minutes. I have skinny hands though. I pulled out the headlight housing, and the blinker light housing, and stuck my finger through to the lens. They both popped right out. The only thing is I know here in Texas your flashers can be any color between White and Amber. You'll have to check your local laws. Again, I did this without even taking teh lights off the car.
Old Dec 29, 2010 | 05:05 AM
yetti96's Avatar
yetti96
Well here are a couple, I still need to do a full thread/write-up but my laptop wifi card is down and I need to use the 6' lan cable to use the internet, or send it back for the warranty repair (who knows how long that will take). So I can get on at work but not enough time to really make a decent post and thread so here you are.
This is where I started:
This is 3/4 of the dremeling, I removed the rest at the bottom of the circle and even more to the top.
Partly there:
One headlight before rotational adjustment at 25':
Old Dec 29, 2010 | 04:57 PM
automan21's Avatar
automan21
Nice, so how does the projector stay in there? sealant or somekind of bracket? Where'd you get the projectors from? Sorry, for all the ?s.
Old Dec 29, 2010 | 05:15 PM
yetti96's Avatar
yetti96
No problem, without totally jacking this thread...I got the projectors at TRS, The Retrofit Source. They mount on a threaded shaft with locking rings to sandwich the factory housing in between the projector and the set of rubber gasket and locking nuts.
Old Dec 31, 2010 | 02:40 PM
automan21's Avatar
automan21
Well I did my lens removal today. Took like 15mins all together. Love the look, forgot to take pics though lol. I ordered the silvervision bulbs to flash amber whenlit but silver when off... the bad thing is I got the py21w bulb where the pins are offset 160 degrees rather than 180 degrees. So they dont fit.
Old Jan 2, 2011 | 11:49 PM
Rob490's Avatar
Rob490
Just removed the lens today. No need to change Lightbulb in CA. Took about 30min with a friend. Easy when you know what your doing
Kimolaoha
Jul 5, 2023 01:04 PM
Rai1gun
R60/R61 Stock Problems/Issues
Jan 11, 2016 05:52 AM
desant89
R55 :: Clubman Talk (2008+)
Sep 3, 2015 04:56 AM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
