R50/53 Speedo reading < then Scanguage
Old Sep 8, 2010 | 12:57 PM
NightFlyR's Avatar
NightFlyR
Normally i dont even look at my Speedo as it is hard to read anything past 60 MPH the way my seat is adjusted. I happen to glance at my scanguage MPH today on the highway and my speedo , very odd that the speedo was about 6 to 8 MPH slower then the scanguage. I think the Scanguage is reading correct, and the speedo is off, has anyone had this issue?
Old Sep 8, 2010 | 01:28 PM
Aquasar's Avatar
Aquasar
Yes that has been a known problem since the beginning. I will admit mine is only 2mph off.
Old Sep 8, 2010 | 02:06 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by NightFlyR
...very odd that the speedo was about 6 to 8 MPH slower then the scanguage....
The speedo usually reads high. Did you changes wheels or tires? If the sizes of your wheels or tires changed, then it could make that much of a difference.
Richh
Old Sep 8, 2010 | 02:16 PM
Eric_Rowland's Avatar
Eric_Rowland
Mine also reads ~2mph shy at 60 vs scangauge - Your 7-8 mph, what speed is that at? (careful - no racing! )
Old Sep 8, 2010 | 03:17 PM
NightFlyR's Avatar
NightFlyR
Pretty slow actually, under 40. No tire swap in over 2 months, I did just do 2 seafoam treatments,
Will watch it more closer tonight when I go to work
Old Sep 9, 2010 | 06:15 AM
thulchatt's Avatar
thulchatt
Is your SGII adjusted based on a GPS? If not do that first as the SGII needs it most of the time.
In my MINI the Speedo is almost spot on because I change to 215/45-17 tires. The surprise for me is that my Odo reads about 3% low.
I guess I am ok with showing fewer miles than I actually use.
In my Miata both the Speedo and Odo are spot on with GPS confirmation.
Old Sep 9, 2010 | 06:43 AM
ScottRiqui's Avatar
ScottRiqui
What you're seeing is normal for MINIs. Typically, in a MINI with stock tires, the speedometer will read a few percent fast and the odometer will be very close to correct.
When you switched to larger-diameter tires, your car is now traveling further per wheel revolution than before, so your speedometer is closer to correct. But now your odometer will read low, as you've already noticed.
Old Sep 11, 2010 | 06:11 PM
Fatherdeth's Avatar
Fatherdeth
Mine has always read 2 mph's higher according to my Scangauge and Nuvi. Typical 205/45/R17 tires on mine.
Old Sep 11, 2010 | 06:41 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Same here.
Old Sep 11, 2010 | 09:07 PM
NightFlyR's Avatar
NightFlyR
Whatever problem I was having is gone, I have watched it the past 2 nights and it is almost spot on, from 10 MPH all the way to 70, read perfect. Just another quirk
Old Sep 12, 2010 | 06:19 AM
Walt's Avatar
Walt
I am confused. Would not changing tires also throw off the scanguage too?
Old Sep 12, 2010 | 06:57 AM
ScottRiqui's Avatar
ScottRiqui
I was just referring to thulchatt's post, telling him that it's normal for the speedometer and odometer to read lower after switching to larger tires.
But you're correct - switching to larger (or smaller) tires will affect a Scangauge as well.
JaggerCoop
Sep 15, 2015 06:17 AM
potterstein
Sep 13, 2015 09:57 PM
potterstein
Sep 11, 2015 09:24 PM
HogWldFLTR
Sep 8, 2015 05:25 AM
