Wheel bounce around corners
Old Aug 19, 2010 | 10:53 AM
thecanuck's Avatar
thecanuck
Hey All,
I had a question regarding cornering at moderate speeds while accelerating.
Is it normal for my front end to "bounce" a bit, as if the wheels loose grip, while accelerating around a corner? My 03 MCS is 100% stock. I do know my upper strut mounts are cracked a bit and need to be replaced, but would that really cause this?
I would like my acceleration around a corner to be smooth, with no wheel hop. Any help?
Old Aug 19, 2010 | 11:16 AM
MiniMacPR's Avatar
MiniMacPR
I would check the condition of your front control arm bushings, They tend to cr@p out over time.
Old Aug 19, 2010 | 04:57 PM
MINI33342's Avatar
MINI33342
Exactly.....lca are the culprit and the strut bearings will add to the problem.
Old Aug 19, 2010 | 05:28 PM
Dr Obnxs's Avatar
Dr Obnxs
Was it always this way?
Tire and wheel selection can add to this too....
check this out. Here people had the very same problem that was traced to the stiffness of the tires used.
I also found this thread. It's excellent reading (for the most part as well).
Matt
Old Aug 19, 2010 | 06:42 PM
thecanuck's Avatar
thecanuck
Ah you guys are great. Thank you.
03BRG's Avatar
03BRG
control arm bushings- Had the same problem that did not happen when it was younger. New one all is well!
Old Aug 19, 2010 | 10:36 PM
thecanuck's Avatar
thecanuck
I like the common theme here. LCA it is then. Will have these replaced asap. Thanks all.
Old Aug 19, 2010 | 11:20 PM
Eric_Rowland's Avatar
Eric_Rowland
Depending on your mileage, the shocks could be suspect as well.
Old Aug 19, 2010 | 11:23 PM
thecanuck's Avatar
thecanuck
100K miles. How do I check to see if the shocks are still ok?
Old Aug 20, 2010 | 12:17 AM
thecanuck's Avatar
thecanuck
Do I have to buy the entire LCA assy or just the bushings? Are there aftermarket better than OEM parts? If so, could someone provide a link.
Old Aug 20, 2010 | 12:30 AM
thecanuck's Avatar
thecanuck
Is this what I need? http://www.waymotorworks.com/powerfl...ll-joints.html
Old Aug 20, 2010 | 07:48 AM
Dr Obnxs's Avatar
Dr Obnxs
The powerflex units are fine....
and you can get the bare, or pre-installed into the bushing holder. The stock units degrade over time, and they are too soft to start with, this allows the control arm to move.
But I'm not in the camp that belives all these problems are from the LCA bushing. I'm in the camp that there is a suspension on the car that is asked to cover too many tire/wheel combinations and that means it's not optimized for the bigger wheel/stiffer or shorter sidewall combinations.
The LCA bushing will improve a lot of things, but like some others have found, it's not going to be a universal cure for "skipping sideways" in turns on rough surfaces.
Matt
Old Aug 20, 2010 | 08:16 AM
thecanuck's Avatar
thecanuck
Thanks for your input Matt, much appreciated.
Old Aug 20, 2010 | 04:52 PM
MINI33342's Avatar
MINI33342
Only replace them if they are bad......no one was saying to replace them just for replacements sake.
theblackfalcon
Oct 11, 2015 09:49 AM
Colt45Magnus
Sep 7, 2015 10:47 PM
dscott90000
Aug 23, 2015 08:21 PM
PatrikKN
Aug 5, 2015 09:10 PM
