Drivetrain Unichip question
Old Aug 1, 2010 | 03:09 PM
chisss's Avatar
chisss
Unichip question
Hey peeps,
So I got a used unichip. I sent it to them to get it mapped.
I see it has 2 switches and a red light. 1 switch has 2 red/yellow wires and the other switch has 2 yellow wires. What are those and what does the light mean? It's never on btw
Old Aug 2, 2010 | 06:24 PM
chisss's Avatar
chisss
anyone?
Old Aug 2, 2010 | 06:44 PM
Yeah.ThatsRice.'s Avatar
Yeah.ThatsRice.
Unichip...
Old Aug 2, 2010 | 07:09 PM
chisss's Avatar
chisss
I know... Please stick to the question tho thanks.
Old Aug 3, 2010 | 03:08 AM
howsoonisnow1985's Avatar
howsoonisnow1985
Hmm, maybe one switch is for bookend mode and the other is for paperweight mode. JK
Old Aug 3, 2010 | 04:34 AM
ZippyNH's Avatar
ZippyNH
If I remember right, from one of the guys that talked about having a Unichip, when you install it, you have 2 choices of the amount of timing advance, basicly for 91/93 octane....
Not 100% sure, but so many folks have toyed with Unichips, somebody should chime in!!
Old Aug 3, 2010 | 05:29 AM
Yeah.ThatsRice.
The only people I know on this forum that I know of that trust Unichip are the Alta guys.
Old Aug 3, 2010 | 05:48 AM
broadwayline's Avatar
broadwayline
Sell it.
Old Aug 3, 2010 | 08:37 AM
Yeah.ThatsRice.
Originally Posted by broadwayline
Sell it.
Old Aug 3, 2010 | 08:42 AM
iwashmycar's Avatar
iwashmycar
I think they are usually supposed to switch between maps.?
I know mine had one switch, and if I switched it the car just wouldnt do anything lol... so it was obviously not programmed. Basically was ECU on/off.
instructions: for 06 S
http://www.unichip.us/system/uploads...structions.pdf
Old Aug 3, 2010 | 09:06 AM
ALTA_Jarid's Avatar
ALTA_Jarid
When they work, they work good. I have had one on my 06 S since 07 and its still rockin. Contact Unichip directly for questions or support. ALTA has not sold the Unichip products since fall-ish of 08.
Old Aug 3, 2010 | 09:07 AM
Aeromax's Avatar
Aeromax
We tried this particular Unichip in question, my own paperweight comments aside, on my own Mini. I tried both switches, to no effect according to my butt dyno, and the red light was never on. :shrug:
Old Aug 3, 2010 | 09:12 AM
ALTA_Jarid's Avatar
ALTA_Jarid
If there are two maps loaded on the Unichip, the switch on the side switches from map to map.
Old Aug 3, 2010 | 12:42 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
When you kick a cow pat, expect flies...
I had a Unichip for a year or so. I even sent it back to Unichip to get reprogrammed. Mine had 2 switches: one to switch between maps for different octane ratings. The other was supposed to turn on some programmed feature, such as a sprayer for the IC at a particular rpm or load, but it wasn't implemented.
Neither of the switches worked. And neither did the Unichip for that matter...
Since then I've had an RMW tune and a Mynes tune. Both worked!
Old Aug 4, 2010 | 04:42 PM
Aeromax's Avatar
Aeromax
I think you know what to do, Paul...
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
bADbOYbECK
41
Oct 16, 2015 12:39 PM
marc0011
Sep 10, 2015 10:04 PM
