Stripped air intake torx screws
Old Jul 19, 2010 | 06:11 AM
fishbone's Avatar
fishbone
Whoever last replaced the air filter on our Mini (we bought it used), stripped both torx screws that hold the intake together, most likely overtorqued them :( Anyone run into this in the past? Any suggestions for an easy fix? I'm thinking I could go one step larger screws, but not sure what size I should use.
Old Jul 19, 2010 | 07:39 AM
Sidmind's Avatar
Sidmind
Same problem with me, 3 week old (used) 2003 mini cooper.
I had to use zip ties to keep it closed. looking forward to the replies.
Old Jul 19, 2010 | 08:12 AM
ramjet77's Avatar
ramjet77
How about filling the holes with ABS cement used to glue pipe together, redrill smaller holes, and let the screws self-tap themselves in?
Old Jul 19, 2010 | 08:21 AM
fishbone's Avatar
fishbone
Some people have also suggested using CA glue. I might give that a try. The bottom assembly is around $30 at the dealer, so if I can fix the holes, yay me.
I fear that ABS cement might crack when drilled/screwed in? Also, when you pour it in, it is I think harder than the plastic, so you might end up drilling the hole at an angle by accident.
Thanks for the idea Sidmind, I'm going to zip-tie mine until I fix it.
Old Jul 19, 2010 | 08:54 AM
davisflyer's Avatar
davisflyer
Happened to me, I just put slightly larger screws in. No problems.
Old Jul 19, 2010 | 08:55 AM
burley's Avatar
burley
I bought a new air box for less than $100 from the dealership. The only reason I didn't "fix" it on my own was because I sold the car and the buyer didn't like my mickey mouse fix.
Old Jul 19, 2010 | 09:45 AM
apexer's Avatar
apexer
JB Weld, drill it and tap new threads
Old Jul 19, 2010 | 05:24 PM
earlrabbit's Avatar
earlrabbit
I had the same problem but I approached it a little differently. I drilled out the hole to accept a 10-32 stainless steel blind nut and epoxied them to the bottom of the air box and use a couple of 10-32 stainless steel machine screws that will never corrode.
Old Jul 19, 2010 | 08:46 PM
apexer's Avatar
apexer
Thats a great idea.
Old Jul 19, 2010 | 09:26 PM
jasoncolorado's Avatar
jasoncolorado
Same here...but then with Alta CAI.
ebowling
90
Aug 4, 2019 09:15 AM
minimofo
Oct 25, 2015 05:53 PM
Aug 27, 2015 03:18 PM
Herleman
Aug 16, 2015 06:41 PM
