Whoops! My thingy popped off!
Old May 21, 2010 | 03:09 PM
karmavore's Avatar
karmavore
When I was jacking up my car for the first time I managed to pop off the rubber block "thingy" at the jack points. Is there any hope of reattaching it?
I also worry about water getting up in the frame, but maybe I'm obsessing.
Any thoughts are appreciated.
Old May 21, 2010 | 03:48 PM
CRoth's Avatar
CRoth
It's not a problem. Just look underneith your frame rail where your "thingy popped off" and find the hole. Then just push it back in place by pushing that little thingy on top of your thingy into the hole. LOL once you have it started you can use your Jack for extra pressure if needed. It will just pop back into place.
Old May 21, 2010 | 04:36 PM
karmavore's Avatar
karmavore
I tried, but the hole is too, ahem, loose and it just falls out.
Old May 21, 2010 | 05:30 PM
CRoth's Avatar
CRoth
LMAO!!!! You must have bent the hole a bit. If it were me, I'd try to use a moly bolt of some type. You can get them at a hardware store. It's basically a piece of metal that looks like a hinge kind of. It colapses as you push it through the hole and opens back up on the inside to give you a base to screw into. You would then drive a bolt through your jackplate "thingy" and into the moly that is now inside your frame rail. Wow, as simple as that is I think I just confused myself with my own explanation.
Old May 21, 2010 | 05:42 PM
tedswoods's Avatar
tedswoods
Sorry about your 'thingy', but you sure know how to title a thread...
Old May 21, 2010 | 06:18 PM
gear-head's Avatar
gear-head
My solution was "Gorilla glue", and leave it jacked up in there for an hour. The thing is solidly attached now.
Old May 21, 2010 | 06:44 PM
karmavore's Avatar
karmavore
Gorilla glue will bond to metal?
silhouette88's Avatar
silhouette88
Best thread title ever!!! I'm glad your thingie is solidly attached again.
Old May 21, 2010 | 06:52 PM
Madurodave's Avatar
Madurodave
Are you sure the hole is loose or is your thingy too small?
Old May 21, 2010 | 06:55 PM
karmavore's Avatar
karmavore
Are you suggesting my very hard and very black thing isn't adequate?
Old May 21, 2010 | 07:56 PM
RJKimbell's Avatar
RJKimbell
I could take that comment and run with it...BUT this is a Family Show!!
Old May 21, 2010 | 08:05 PM
gear-head's Avatar
gear-head
yes, be careful, Gorilla Glue will bond to your thingy ...
Old Jun 19, 2010 | 02:28 PM
apexer's Avatar
apexer
When using a lift with rubber pads, is it safe to use the "Thingy" as a jack point? Didn't know if this hard plastic piece would break/crush if you placed the pads from the lift on these points to lift the car.
Old Jun 19, 2010 | 02:42 PM
ngweibing's Avatar
ngweibing
haha.. i like the comment..
Old Jun 19, 2010 | 03:01 PM
karmavore's Avatar
karmavore
I put very little prsessue on the thingy before it popped off. I don't see how it is meant to be used.
I was using a floor jack, BTW.
Oh, and replacing it was easy. Out Motoring has them for $15.
Old Jun 19, 2010 | 03:34 PM
CRoth's Avatar
CRoth
Those jack points (thingy's) are designed to receive the factory jack. When I use a floor Jack on my car, I start with the factory floor Jack to raise it up enough to fit my floor jack underneith my frame with a 3 foot 4" x 4" piece of wood in between the jack and the frame. This allows even distribution of weight so no damage will occur to the frame. Once I have it high enough I put a Jack stand underneath the "thingy" and use those points for support.
Old Jun 19, 2010 | 03:43 PM
not-so-rednwhitecooper
Its meant to take load straight up, not at an angle. You probably put load on it on an angle. You need to push the pin underneath from the center to spread the legs to grab onto the frame rail. Don't glue it, thats a terrible idea.
Its only a $23 part from thee dealer.
Its called a jack point.
Old Mar 13, 2012 | 07:12 AM
minimini482's Avatar
minimini482
Sorry for resurrecting such an old thread but I figured this was better than starting a new one - plus the subject of this one is great.
Someone posted above a question on these jacking points: I want to confirm they will NOT crush under the weight of the car when using a jack and/or jack stands? Is it suggested to put one of the expensive aluminum pucks (or a cheap hockey puck) between the plastic jack point on the car and the jack stand?
Just want to make sure they wont simply crush as I lift the car up by them or lower it down onto jackstands (may use the 2x4 on the frame rail method to get the entire side of the car up).
Thanks in advance for your feedback!
Old Mar 13, 2012 | 09:41 AM
apexer's Avatar
apexer
No they won't crush. I use a 2x4 on the frame if I'm jacking the car up at home then, I use the "Thingy" to insert the jack stands.
When using my friends lift, I put the lift pads right on top of the oem jack pucks.
Old Mar 13, 2012 | 10:04 AM
drsimmons's Avatar
drsimmons
I had 2 missing when I bought my car and ordered some nice aluminum ones made of billet, painted black, and they attach with toggles.
Got them from www.waymotorworks.com Kind of expensive ($95) but they are well made.
scfiveo
Sep 27, 2019 02:27 PM
MINI Stupor
Oct 1, 2015 11:36 AM
patsum
11
Sep 30, 2015 02:20 PM
TifosinDel
Sep 28, 2015 10:45 AM
MiniChick82
Sep 16, 2015 02:56 PM
