R50/53 Cant find rain gutter piece?
Old May 19, 2010 | 03:45 PM
simpsonna's Avatar
simpsonna
I'm missing the ~5" piece if rain gutter over the front drivers side pillar. It looks like it just snaps on so I guess it either blew off or someone really wanted a sample of my awesome car
It doesn't seem like a really expensive piece, but I can't find it anywhere. I don't want to go the dealership route cause Ill pay more for shipping than I will for the part.
Anybody seen one?
Thanks again guys, Nick
Old May 19, 2010 | 03:50 PM
HRM's Avatar
HRM
Some parts are dealership only for new.
Personally, I would try a junkyard. This is a classic example of a part you can look at and see if it is OK. If it snaps off easy, it should go on easy too. Looking at it will tell you if it is what you need or not.
Old May 19, 2010 | 11:46 PM
chaseabryant's Avatar
chaseabryant
That piece can only be purchased along with the entire drip rail. The drip rail itself is probably going to run you 55-75 dollars.
I had the same thing happen to me. Turns out the person that owned the car before took it to a pretty sketchy place to have the windshield done, and they tore the front area up pretty well.
Sorry, I know this isn't what you want to hear. Just get it from the dealer as shipping will probably wind up being exorbitant because of the box's dimensions.
-Chase
Old May 20, 2010 | 02:45 PM
Ministrater's Avatar
Ministrater
Yep, got mine (the whole gutter piece) from the stealership. Cost around 80 bucks with tax. I then unclipped the part I needed and snapped it onto my car. It took a little fussing but it finally went on. Been through the drive-thru car wash maybe 4 times now and it has stayed put.
Old May 20, 2010 | 06:52 PM
simpsonna's Avatar
simpsonna
Thanks guys, I guess Ill be trying to find one in a junkyard that I can get the piece from, $75-80 is a bit much for a college student. haha.
Old May 21, 2010 | 05:26 PM
chaseabryant
Be careful when removing the (in-tact) drip rail. The front piece that you are missing has a receiver for a nub, so trying to force one off will wind up breaking it just like your current one.
To remove it you will need to peel off your door seal, undo the four screws that hold the drip edge to the roof, unclip from the rear, slide forward slightly and you should be able to get everything off safely!
-Chase
Old May 27, 2010 | 03:37 PM
clmson89's Avatar
clmson89
Just priced it at the dealer and they want $119 for the rain rail. Mine is loose, so i guess i better hit it with something sticky!
Old May 27, 2010 | 04:01 PM
inimini2007's Avatar
inimini2007
Try this
http://www.car-part.com/
or
http://www.usedminicooperparts.com/
Old May 27, 2010 | 04:44 PM
chaseabryant
WAAAYYY too expensive. Do you have any other dealerships in the area?
Also, if it is loose, try removing the rail and re-installing it. It could be that the little portion at the front just wasn't installed correctly. Mine for some reason had come loose after I had installed it. After re-installation, all was good.
-Chase
Old May 27, 2010 | 04:54 PM
Ministrater
The dealerships must have caught wind that Minicarparts.net is no longer selling the little gutter piece. Cha-ching!
Old May 27, 2010 | 05:05 PM
Eric_Rowland's Avatar
Eric_Rowland
Originally Posted by Ministrater
...Been through the drive-thru car wash maybe 4 times now and it has stayed put.
Old May 27, 2010 | 05:23 PM
AKIndiMini's Avatar
AKIndiMini
Aw, that's not what I wanted to hear ! I need both pieces for mine. It looks like a windhshield installer in the past messed mine up - they were both cracked right where they hook on to the snap-lock fasters on the A-pillar.
Old May 28, 2010 | 04:18 PM
Ministrater
Originally Posted by Eric_Rowland
Risky business, I know.
I used to work at one back in high school. Used to see some crazy stuff. Ever see a guy try to change a tire inside the wash while it's running?
The Brown Bear around here has a policy of fixing any damage as long as it is discovered before you leave so be sure to give your car a good walk around!
WarEagle
R55 :: Clubman Talk (2008+)
May 3, 2019 03:00 AM
trw92a
Aug 26, 2015 01:47 PM
NickBchillin
Aug 26, 2015 01:22 PM
sevin
Aug 24, 2015 09:26 PM
MES11
Aug 8, 2015 10:21 AM
