R53 has no reverse light.. help
Old Mar 20, 2010 | 06:47 AM
stock_r53's Avatar
stock_r53
First I am new to this site and any help received will be greatly appreciated. I have no reverse light: I have already checked the fuse and replaced it just in case, replaced bulbs, tail lights assembly, and went as far as replacing the backup light switch #BS31609. Still with no luck.. I am guessing theres a short in my wires but finding a short somwhere is beyond me. So before I turn her in to a dealer I figured I give you guys a try
Old Mar 20, 2010 | 04:01 PM
Fatherdeth's Avatar
Fatherdeth
9 times out of 10 it's your reverse light switch. It's located om the gearbox housing. Kind of a pain to get to. It could be bad or just dirty.
Old Mar 20, 2010 | 05:03 PM
rkw's Avatar
rkw
What is this part you refer to (not a standard MINI part number)? Do you have manual or automatic transmission, and what year is it?
Old Mar 20, 2010 | 05:42 PM
stock_r53's Avatar
stock_r53
I have a 2002 standard mini cooper S. Well I went to BMW / mini in va beach blvd told them i what i needed and thats the part no. on the bag of the pressure switch that they gave me. looks just like the one i removed.
Old Mar 20, 2010 | 05:43 PM
stock_r53's Avatar
stock_r53
replaced that switch already
Old Mar 20, 2010 | 06:04 PM
rkw's Avatar
rkw
If you have a 2002, I'm confused about your comment about replacing bulbs (plural) and taillights. Your reverse light is the single light in the center of the bumper.
Old Mar 20, 2010 | 09:17 PM
Fatherdeth's Avatar
Fatherdeth
Yeah, me too. Well I guess it has to be a broken or cut wire somewhere.'the only other thing is the gear box isn't knocking that switch the way it's supposed to.
Old Mar 21, 2010 | 08:55 AM
cristo's Avatar
cristo
Alliance Member
MINI part number is 23117527716
Should be less than $20.
http://www.realoem.com/bmw/showparts...17&hg=23&fg=15
Old Mar 21, 2010 | 04:10 PM
stock_r53's Avatar
stock_r53
HUH?? ok I have had this mini for a total of 2 weeks, love the car but your saying that the reverese light is in the center of the bumper.... all i have is a black cap where i guess somthing goes and my tail lights have a bulb on the bottom that dont light up. I had stock lights and when the bottom light didnt work i bought LED lights then they still dint work. but your saying my reverse light is in the bumber?
Attached Thumbnails R53 has no reverse light.. help-ultra-led-taillights-small.gif   R53 has no reverse light.. help-30760140105_large.jpg
Old Mar 21, 2010 | 04:18 PM
mjobrien's Avatar
mjobrien
Yep. Right between the Alta decal and the exhaust tips in the picture you posted.
Old Mar 21, 2010 | 04:41 PM
stock_r53's Avatar
stock_r53
so iafter i read the last post and i replied i decided to go and envestigate. sombody covered the reverse light with a plug!!
Old Mar 21, 2010 | 05:25 PM
rkw's Avatar
rkw
Here's some information you may find useful...
2002-2004 had a single reverse light in the center bumper.
The taillights were updated in 2005. The reverse light was moved to the bottom corner of the two taillights. The center bumper became the location for the rear fog light (black plug if the car has no rear fog option).
The LED taillights you purchased are the 2005+ design with integrated reverse light. They can be fitted on a 2002 but your original wiring harness does not include the reverse signal. You'll have to splice in the signal to make reverse work in those taillights.
What type of taillights did you swap out (with or without integrated reverse light in the corner)? It's confusing that in a 2002 you would have a black plug where the reverse light should be. I doubt that the black plug was even available until 2005, when it was created for new cars with no rear fog. Are you sure your car is a 2002?
Old Mar 21, 2010 | 06:12 PM
Fatherdeth's Avatar
Fatherdeth
Wow, this is getting good. So, I guess the original owner decided that he didn't need reverse lights or didn't know how to modify the wiring for the newer light housing's reverse lights. Or, as stated above, this ain't no 2002!!
Old Mar 22, 2010 | 12:29 PM
stock_r53's Avatar
stock_r53
I guess so..I just purchased the reverse light pluged it in and it works fine. My mini is defitnatly a 2002 it just had 2005 and up stuff. So now I have to wire up the tail lights so i have a reveres light there also. I will post pictures later
Old Mar 22, 2010 | 04:25 PM
Fatherdeth's Avatar
Fatherdeth
Glad you got it figured out. To behonest, the single reverse light isn't the greatest anyway. I think they only did It to be like the original Mini's set up.
Old Mar 22, 2010 | 06:10 PM
stock_r53's Avatar
stock_r53
Thank you guys who helped me thrugh my mini dilema, next will project will be reducing the pulley on the super charger to 15%. After market intake and exaust have been installed just waiting for my pulley and msd coil pack
Mb460
Aug 20, 2016 10:39 PM
Filmy
Sep 7, 2015 08:27 PM
desant89
R55 :: Clubman Talk (2008+)
Sep 3, 2015 04:56 AM
I_drive_slow
Aug 18, 2015 10:47 AM
BoCRon
Aug 17, 2015 01:21 PM
