How To DIY Requests....
Old Jan 31, 2010 | 09:54 AM
Motor On's Avatar
Motor On
DIY Requests....
A place to post up what you'd like to see others put up for DIYs.
Old Jan 31, 2010 | 01:46 PM
Mini_Onslow's Avatar
Mini_Onslow
My request.. How to change the spark plugs for R53. Thanks!
Old Jan 31, 2010 | 02:29 PM
ACallahan's Avatar
ACallahan
Thermostat switch out
Getting rdy to switch out my stock thermostat with a 180 degree M7, dont know if anyone has already posted a DIY for this one and I dont have a Bentleys service manual. Got a pretty good idea of what to do but I always like to see a walkthru first.
Old Jan 31, 2010 | 02:54 PM
cartar452's Avatar
cartar452
How to pull the engine.
Old Feb 1, 2010 | 10:47 PM
TypeS619's Avatar
TypeS619
how to install injectors plz
Old Feb 2, 2010 | 09:20 AM
jbkone's Avatar
jbkone
alternator
how to replace alternator and belt (and whatever else you should do while in there)
Old Feb 4, 2010 | 08:38 PM
04Mini-S's Avatar
04Mini-S
How to add Seafoam through the intake (R53's) with pics would be great .
Old Feb 10, 2010 | 07:26 PM
Un0RiGiNaL's Avatar
Un0RiGiNaL
How to remove your stereo
(I know its a simple DIY, but it helps add a variety to the how-to section and itll only take 15 minutes for someone to make one)
Old Feb 11, 2010 | 08:44 AM
grccwill's Avatar
grccwill
Rear View Mirror Cover
I have a 2010 MINI and have just gotten a checkered rear view mirror cover. I've been looking for instructions on how to put it on, but can't find any. Anyone out there know how or can give me a link to a post that explains it?
Thanx in advance.
Old Feb 27, 2010 | 10:55 PM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
Headliner?
Does any one know how to remove the headliner on an R53 without breaking it? I want to cover it in fiberglass and paint to match the car, but cant get the thing out! Any help and pics would be great
Old Feb 28, 2010 | 04:22 AM
marcel74's Avatar
marcel74
This probably would need to be split in "How to remove a head-unit" and "How to remove front speakers" and "How to remove back speakers". Furthermore , the headunit is built-in differently in a 1st Generation new mini (R50,R52,R53,R54) than a 2nd Generation (R56-55-57) and a single topic would not be specific enough.
This is covered in https://www.northamericanmotoring.co...the-clips.html for the external mirrors (a replacement of existing part).
The internal mirror cover is simply by using double-sided sticky tape on the inside of the cover, then making sure it is aligned 100% properly, then holding it for two minutes while applying pressure. Unfortunately I could not find a specific topic about this.
Old Mar 3, 2010 | 03:06 PM
kcle730's Avatar
kcle730
If possible, did anybody done a Transmission Oil Flush DIY?
Thanks in Advance
Old Mar 13, 2010 | 09:25 PM
RCCAR's Avatar
RCCAR
Here ya go!
Spark Plug Writeup.pdf
Old Mar 24, 2010 | 11:38 AM
thebigf's Avatar
thebigf
Dealer fix is more grief than doing it myself. I've got a Haynes, a new stat and a new housing coming, I'll try to put something together.
Old Apr 3, 2010 | 11:29 AM
dubyas's Avatar
dubyas
Lower engine mount replacement please.
Old Apr 4, 2010 | 12:16 AM
DICKS GARAGE R53
Really simple, it is only two bolts and jacking the front of the car off the ground to get at the lil-bugger, Oh make sure to use jackstands and support the motor with your jack/ a pice of 2X6 will keep you from damaging your oil pan
Old Apr 26, 2010 | 06:04 AM
MiniMio's Avatar
MiniMio
+1 on the injector install.
Old Apr 28, 2010 | 05:27 PM
Louie B.'s Avatar
Louie B.
How to replace a ripped inner CV shaft boot. All the threads I've found say they consulted a Haynes manual but Haynes' website says they don't make a MINI manual!
Old Apr 28, 2010 | 06:09 PM
Dr Obnxs's Avatar
Dr Obnxs
I already did this one...
https://www.northamericanmotoring.co...247-post6.html
It's easy...
Matt
Old May 6, 2010 | 11:03 AM
jwplocks's Avatar
jwplocks
A/C Diy
I would like to see a/c clutch electrical testing, best way to access the wires.test (find) low pressure switch. R & R a/c compressor. Working on mine now. I hope it is just low on suds.
Old May 18, 2010 | 09:24 PM
stone03's Avatar
stone03
supercharger pulley w/ belt
Old May 18, 2010 | 11:49 PM
soccerbummer1104's Avatar
soccerbummer1104
stone.
just follow the instructions that come with the pulley and you will be fine. I did it in 4 hours a year ago today when i was still 17. (ok i turned 18 4 days later... but i was 17 when i did it..., regardless.. its not hard. just make sure you have a torque wrench with allen sockets)
Old May 19, 2010 | 01:05 PM
zachsa's Avatar
zachsa
i need updated sc pully install instructions
theres only one sc pully how to on this thread and cant find anymore...the one on here doesnt have pics anymore cuz it was written in 2003!!!
anyone with links that has a sc pully install with pics?
Old May 19, 2010 | 01:30 PM
Motor On's Avatar
Motor On
http://www.mini-madness.com/pdf_file...EY_INSTALL.pdf
Old May 19, 2010 | 03:18 PM
thebigf's Avatar
thebigf
Mini Mania have '01 to '05 Haynes as far as I could tell, I have an '06 so got mine from Ebay in the UK.
Manual number 4273 for 'July 2001 to 2006 (Y to 56 reg) Petrol' book.
See http://cgi.ebay.co.uk/HAYNES-MINI-bm...43381791145879
Seller User ID: motoringbooksofbookham
Your total is:
£14.98 per item
insurance
£0.00 Sales discounts (-) or charges (+)
£7.56 postage/packing
£22.54 = Total
