Navigation & Audio HK still having door rattle issues on 04's?
Old Nov 11, 2003 | 02:19 PM
antsmini's Avatar
antsmini
Was thinking about getting a 2004. Does the HK system still come from the factory with that horrib passanger side rattle?
Old Nov 11, 2003 | 02:20 PM
C4's Avatar
C4
'04 MCS, 1,300 miles and no problems with the HK stereo system, including speaker rattles.
Old Nov 17, 2003 | 06:16 AM
LeeL's Avatar
LeeL
Mine buzzes on the front right speaker so I am looking for the fix right now. I only got it 2 days ago.
Old Nov 17, 2003 | 06:24 AM
countrym's Avatar
countrym
I picked mine up Saturday, so far, so good. I know one other person (besides LeeL) in the Nov. club has a H/K rattle.
Old Nov 17, 2003 | 06:26 AM
Blue Brummie's Avatar
Blue Brummie
Picked up BB on Thursday (H/K), and no rattle detected. I've had the volume all the way up, and I've kept the base at one notch above middle.
BB-
Old Nov 17, 2003 | 06:59 AM
MNESIAC's Avatar
MNESIAC
I got my car 10/28/04 and developed the rattle about
a week later. It's not terrible and not ALL the time but
it's annoying when your car is only 2-3 weeks old and
should still be pristine! I've found myself turning the bass
down a bit to avoid it...
Old Nov 19, 2003 | 11:41 PM
KatanaPilot's Avatar
KatanaPilot
I have a early 04 (built on 9/4/2003) and I had the HK rattle within a week of taking delivery.
After searching on the web and learned the fix, I stuffed a strip of cardboard between the door panel and the door. Still rattle free after a month and a half.
My right side tweeter cover is also popping out; I can't get it to snap back in.... So much for HK quality......
Old Nov 20, 2003 | 06:38 AM
LeeL's Avatar
LeeL
KatanaPilot,
SInce it will be a while before I am back at the dealer, I would like to do what you did. Did you just cut a small strip and wedge it in from the passenger compartment? Or did you take the door panel off and do it from the back?
Old Nov 20, 2003 | 03:32 PM
KatanaPilot
If you lightly tap your passenger side lower HK speaker cover, does it make a similar rattling sound?
(you might have to tap harder, just don't break it.)
When you tap it, you could also feel the bottom part of that panel vibrate. Now go to the bottom of the panel, and try to see if your panel moves a bit. If it does, then you have the exact same problem I had.
I cut a strip of cardboard about 1 foot long, less than half an inch wide. I was able to push the strip of cardboard from underneath, between the panel and the metal part of the door.
Total time: about 30 seconds.
And I didn't come up with this; I found it on either here or mini2. Thank you to whoever discovered this first!
woodstudio
Mar 15, 2020 08:28 AM
TREX
Nov 2, 2019 07:31 PM
MiniJess
Detailing 101
30
Aug 4, 2016 03:43 PM
alistaircookie
Oct 8, 2015 10:52 AM
iclancy82
Aug 11, 2015 09:35 AM
