Speedo Indicator lights
Old Dec 1, 2009 | 08:29 PM
JimRoberts12's Avatar
JimRoberts12
2008 MCS
I set cruise and the light is very faint. much more so than TPMS or Fog lights lights. (TPMS on because snows are on right now - FYI)
in the sun i can't even tell if it's on. is this normal or odd? i wonder if the blub fell out and is still lighting up but not in the right spot, something like that
Old Dec 1, 2009 | 09:21 PM
Robin Casady's Avatar
Robin Casady
I don't recall for sure, but it would make sense that it was dimmer than TPMS or fog lights. Cruise control is something you would drive with for extended periods. TPMS is an alert that wants your attention. So it should be brighter. I could see where the fog light indicator would be brighter because you don't want to leave them on when the fog is gone.
Old Dec 1, 2009 | 09:41 PM
MINIDean's Avatar
MINIDean
My cruise indicator is very dim too and it's a 2010. I had a loaner 2009 JCW last week and it was the same way. It's just the cruise indicator though. Must be normal.
Old Dec 2, 2009 | 06:43 AM
sequence's Avatar
sequence
mine is the same way.
Old Dec 2, 2009 | 07:07 AM
immini's Avatar
immini
the little **** on the left tach face is insterment panel brightness
Old Dec 2, 2009 | 08:56 AM
iwashmycar's Avatar
iwashmycar
same w mine. probably because it can potentially be the only one on for extended periods of time.
Old Dec 2, 2009 | 03:47 PM
schatzy62's Avatar
schatzy62
Mine is dim as well. These are lit by LEDs on the circuit board so there is no bulb to fall out and no real way for it to be out of place unless all cars out out of place (that could be possible though).
Old Dec 2, 2009 | 04:11 PM
drewstermalloy's Avatar
drewstermalloy
Mine is just as bright as all the other lights. Weird.
Old Dec 2, 2009 | 08:07 PM
JimRoberts12
yea i'm guessing it's normal based on these replies. however, another stupid "mini thing" there've been several times when i didn't know if the cruise function was on or not because it's so dim in daylight.
oh well...not a biggie
maniacalmorgan
38
Sep 29, 2015 04:56 AM
missinmyjeep
Aug 22, 2015 07:13 PM
one73ronin
Aug 19, 2015 12:36 PM
Herleman
Aug 16, 2015 06:41 PM
