R55 Is this how your footwell looks
Old Sep 21, 2009 | 11:49 PM
motobell's Avatar
motobell
I recently bought a clubman S with just 3900 miles mini next certified from a a dealer..
first strange thing i noticed after it arrived is the driver side door missing a insulation rubber strip.
Second, this looks strange but want to confirm with other.. is this how "open" your foot well looks.. meaning you can see the steering shaft and wires hanging or is this all covered in your car. can you please post your picture?
Attached Thumbnails Is this how your footwell looks-img_0201.jpg   Is this how your footwell looks-img_0205.jpg
Old Sep 22, 2009 | 07:50 AM
gaffer's Avatar
gaffer
They don't put a rubber strip on the Clubman driver's door. You can buy one and snap it on yourself, if you want one. That's what I did. (They stopped putting them on both sides of the R56; claimed they didn't do anything.)
The foot well looks normal to me.
Old Sep 22, 2009 | 07:55 AM
iwashmycar's Avatar
iwashmycar
looks normal. dunno bout the strip...i think my coupe has one.
Old Sep 22, 2009 | 08:30 AM
motobell's Avatar
motobell
are you serious they don't put the rubber strip? why would they leave those holes there just to get exposed and start rust. Not doubting you that sounds crazy
anyone had this installed with car or did you do it yourself like gaffer?
Old Sep 22, 2009 | 09:10 AM
gaffer's Avatar
gaffer
Unbelievable but true. There's a whole thread about this if you want to search for it. The rubber strip is under $20 at Classic MINI parts in the Vendor's directory. It snaps into all of those slots in 5 minutes.
Old Sep 22, 2009 | 09:38 AM
mbu's Avatar
mbu
motobell,
Here are some pictures of the '09 Clubman S if that is of any help...
The steering column looks the same as yours but no wires are hanging down. Both doors on the '09 have weather strip on the bottom.
Attached Thumbnails Is this how your footwell looks-mini-clubman-s-09-002.jpg   Is this how your footwell looks-mini-clubman-s-09-004.jpg
Old Sep 22, 2009 | 09:41 AM
Wolfeee's Avatar
Wolfeee
I have a clubby and my footwell does not look like that... I didn't have the rubber insulation on the driver side.. passenger had it... go figure.. bought mine for 20 includ shipping and popped it in myself...
Old Sep 22, 2009 | 10:27 AM
Alphawave
Guest
Posts: n/a
No wires showing here, and no door rubber on driver side here (2008 July build)
Old Sep 22, 2009 | 10:37 AM
malteseracer's Avatar
malteseracer
I can see the steering shaft on my coupe. That seems to be normal, but no wires
Old Sep 22, 2009 | 11:28 AM
go_mini_go's Avatar
go_mini_go
The inside of car doors are typically open to atmosphere, they have little drain/weep holes along the bottom should any water get inside. There is a plastic membrane behind the door panel that protects the interior from the elements. IMO, These empty holes shouldn't be a worry, in fact, these strips are often the cause of rust due to dirt collecting around them, the dirt retains water and can jump start the rust.
Old Sep 22, 2009 | 01:21 PM
schatzy62's Avatar
schatzy62
+1
as for the foot well it looks as if someone thad some work done on the stereo or somting else and the wiring harness did not get pushed back up hwere it belongs or maybe not strapped back down. From a stereo upgrade and cpumter install i have all kinds of iwres runnign there but i wraped them in sleeving that is black so it does not look so bad.
Old Sep 22, 2009 | 07:39 PM
Benibiker's Avatar
Benibiker
Like go min go said, they started to leave off the weather stripping because it was accumulating dirt, grim, salt behind it and causing rust. If you have it, it would be a good idea to thoroughly rinse the area down when washing the car. Zero seals on my 08 MCS.
Old Sep 22, 2009 | 09:52 PM
motobell's Avatar
motobell
Originally Posted by schatzy62
+1
You have a point, but it bothers me that those holes are exposed..may do what -I my just do what gaffer and wolfee did and get it installed. will clean it out periodically.
Old Sep 22, 2009 | 11:03 PM
Benibiker's Avatar
Benibiker
More holes = more ways for water to drain. But whatever, it's your car, whatever makes feel better.
Old Sep 23, 2009 | 06:54 AM
RadioFlyer's Avatar
RadioFlyer
i have the rubber strip on mine, (09- week 19) from the factory!
Old Sep 23, 2009 | 07:49 AM
gaffer's Avatar
gaffer
The holes for the rubber strip are too high for any water to drain out of them.
UncDeo
Nov 4, 2019 04:08 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
Puggles
R60/R61 Stock Problems/Issues
Sep 11, 2015 11:53 AM
Getrieben
Aug 15, 2015 09:09 PM
