R50/53 best power adders for the r53
Old Aug 29, 2009 | 01:40 PM
slowboyy's Avatar
slowboyy
hello everybody i will like to introduce myself 1st, im a potential r53 owner, use to be a honda tuner so yes im one of them guys but looking for something knew and diff but getting right into it, im looking for some power adders for the 53 i see supertech makes a valvetrain upgrade and im familiar with there products pretty good, i saw some cams upgrades, a pulley,tune,and aside from the usual bolt on what else can i buy to try and get over that 300whp mark i know it will be heard but trust me building a 782whp civic was not easy either so i dont mind working and trial and error, please don't bash me im just looking for some ideas thanks...
Old Aug 29, 2009 | 06:59 PM
howsoonisnow1985's Avatar
howsoonisnow1985
Power Quest
First of all you will need a special tool thats hard to find, its called: Bankroll
If you have it already the you can begin your quest for power. Although, you probably need a reduced pulley and intake as a prereq. RMW is the most common and cheapest (relative term) via: Head, Cams, Header, Exhaust, Injectors and custom dyno tune.
See this thread:https://www.northamericanmotoring.com/forums/drivetrain-cooper-s/174320-new-rmw-power-numbers-277hp.html and: https://www.northamericanmotoring.com/forums/drivetrain-cooper-s/140234-revolution-mini-works-goes-291-7whp.html
And this one: https://www.northamericanmotoring.co...-291-7whp.html
Beyond that, you can go to a 1.8L or 2.0 or even a Rotrex S/C. I see in another post you asked about the twurbo, they have put down 337hp I think, but be prepared with your scangauge and laptop, cause if you look for old threads here on NAM they were plauged by codes thus limp mode. There are also Nitous kits for MINI: Venom/M7, but also same deal as above, think a few peolpe did the tweaks to make it work. But generally, most just don't work consistently. If you got a trailer, to take your car to/and/from events and have extensive knowledge on engine management tuning system it is a very viable option, but if its a daily driver or weekend car, it will end up as a drive way queen. Or if you have a daily driver and weekend car then go for it, it will be the "ongoing project car", but sure will be a blast the momments it does go. There's also turbo options by mines and abf, but don't know much about'em, they're kinda new. Although I've always been from the school of thought that you begin with suspension mods first before power. That said, I would say the very best way to make your car faster is to attend several HPDEs (High Performance Driver Education) at your local track/road course and its only between $200-$500 depending on sanctioning body. In other words, as the saying goes, "to go faster, tighten up [the skills] the nut behind the wheel."
Hope that helps, but read up on threads make your own decision. But pulley, intake, cams, exhaust, and larger injectors are but cheap to start with and won't be irelevant as you build more power either s/c, twurbo or turbo.
rob&JCW
Feb 13, 2023 07:03 PM
JPMontes3
Aug 23, 2015 01:26 AM
Super Coop
Aug 17, 2015 05:09 PM
azntaiji
Aug 13, 2015 03:24 PM
