Hydro and drying
Old Jun 5, 2009 | 08:22 AM
Chimera's Avatar
Chimera
Hydro and drying
So I know a lot of you guys use Hydro while you dry, but what towel do you use to remove it? I see that waffle weave is best for drying, but something like a Monster Fluffy is best for QD....so which is it when using Hydro on a wet surface?
Also since Hydro is concentrated, do you dilute it when using it on a dry surface?
Old Jun 5, 2009 | 08:58 AM
lotsie's Avatar
lotsie
First, I don't use Hydro "dry" I use QD.
After rinsing the soap off, I spray Hydro on the wet surface, then with a waffle weave, I blot dry most of the water off. Then I use a Monster Fluffy to buff off the rest, and shine up the Hydro.
Mark
Old Jun 5, 2009 | 09:00 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Waffle weave on a wet surface. Just like drying any other time. You're just drying off & spreading around a mist of Hydro in addition to drying off the water that's left on there.
I rarely use Hydro on a dry surface. When I do, I do not dilute, but I DO use it very sparingly. And I do NOT use it as a QD - I ensure the panel is clean and pretty dust-free first - then just use Hydro as a gloss "refresher" and swirl filler. In this application, I usually use a Starfish Mitt - but any other plush MF (like Monster Fluffy) will work also.
Old Jun 5, 2009 | 09:06 AM
rockridge's Avatar
rockridge
I have been using Hydro for 18 months or so, and use it after most every car wash. I do however, completely dry my car before using it. I know that it's not the primary use case, but I like doing it this way, and the car looks great.
Old Jun 5, 2009 | 09:36 AM
kenchan's Avatar
kenchan
as far as Hydro i only use it on my dd's... which means i really dont care about minor swirlage cause i have bigger problems to worry about (ex: neighbor's dog peeing on
the wheels, bird crappage, kids crashing to cars with their
bicycles, people leaning against cars while 'hangin out' at
kenchan's place, etc.)
so, after the rinse, i just spray and wipe down with my
DP waffleweave towel. (no blot dry).
then spray at the wet wheels and use a soft paper towel
to wipe down.
looks fantastic.
Old Jun 5, 2009 | 11:38 AM
Chimera's Avatar
Chimera
I can see why you guys buy Hydro by the gallon....so many uses I guess I need to order a couple of waffle weave towels, I was trying to keep my first order under $100 so skipped them before.
Old Jun 5, 2009 | 03:58 PM
BlimeyCabrio
Shoulda just added a zero to your target spend and you woulda been OK.
Old Jun 5, 2009 | 05:21 PM
bee1000n's Avatar
bee1000n
Order lots and lots of waffle weave towels (I usually 2 or 4 every time I order any detail supplies). You should only wash microfiber with other microfiber and you can fit many, many towels into a washer load.
Old Jun 5, 2009 | 07:24 PM
Gil-galad's Avatar
Gil-galad
+1. Each of my waffle weaves transitions through a life-cycle. I use new and lightly used ones for drying and Hydro application to the body--they are perfect for this. As they start to wear and pick up permanent stains, I put them in the pile for use only on door jams and sills, inner area on wheels, etc. The "really used" ones I reserve for places that usually hide a bit of leftover dirt like tires and around the boot seal. Like bee says, they wash up well, but stay away from fabric softeners or they will lose effectiveness and leave a film.
You can never have enough waffle weaves.
Old Jun 6, 2009 | 04:45 AM
kenchan's Avatar
kenchan
Yah, me too. I have dedicated waffles for my MCS and G not the regularly used waffles for my dd's.
And always always always a good idea to plan out your purchase perfectly, then add another zero at the end.
USNAE2
16
Jun 17, 2022 07:17 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
martinb
Oct 7, 2015 05:00 PM
AoxoMoxoA
Tires, Wheels, & Brakes
Sep 30, 2015 06:00 AM
Nicefeet
Sep 24, 2015 06:53 PM
