Suspension NM Engineering torque arm insert install/engine bushings
Old Apr 13, 2009 | 09:24 PM
dtsoccer6's Avatar
dtsoccer6
Ok, so tonight I put the car in the air and decided to put in my Torque Arm Insert from NM Engineering.
From first bolt off to last bolt on, it took 25 minutes. Now, this is obviosuly much easier to do when the car is in the air and you have the proper tools! I used my mechanic's air tools for the most part.
First things first, heres what the set looks like off the torque arm.
Second, went to the car and used PB Buster on the bolts, as they were very tight and rusted. Even with the air tool it was tough, so I sprayed it and it helped loosen the bolt. This stuff is great for loosening anything that seems super tight! Made it much easier.
So heres where the Torque arm goes, in this picture it is off the car.
Here are the tools I used. The assortment of tools was because the sockets I had were both big and small. For the bolt that is closest to the front of the car, it's a tight fit due to the DP. So a smaller 16mm socket is needed. The torque bar is also in this picture, however, the inserts are not yet installed.
The pry bar is also a huge help when trying to get it back in, as the fit is tighter and lining up the bolt holes by hand could be tricky. Something like this.
Now, with the torque bar off the car, the inserts are installed. This the simplest thing you could possibly do. All you need to do is stick the inserts in the bar in the proper place. It's just like playing with the blocks in kindergarten and trying to fit them in the right slots
Then, once you have both inserts in, you put it back on the car, line up the bolts, and bolt it tight to 80 foot lb torque. This is where the pry par could really come in handy, it did for me!
Thats it, the end! Lower the car off the lift and feel an immediate imrpovement in shifting and quicker transfer of power from engine to ground. Even after holding the bar in my hand and trying to move it after it was bolted up, it seemed much more solid than stock. The car felt crisper and more responsive on the throttle.
As for noise and vibration - NO VIBRATION AT ALL! Not in the steering wheel, pedals, or stick shift. Noise, well, at idle there is a slight noise. As soon as I put it into gear, it disappears. I may even need to tighten the bolts harder, I'm going to check tomorrow.
All in all, great bang for your buck and a worthwhile mod. Takes minutes to put in and you recieve immeidate results. Very happy with it and many Thanks to Nick at NAMotorsports for getting me a deal on this piece, a pleasure to deal with as always, thanks Nick!
Hope this helps people decide! Motor On!
Old Apr 13, 2009 | 09:28 PM
dtsoccer6's Avatar
dtsoccer6
Oh and for anyone wondering...my MINI was produced in England on October 13th, 2007. So my torque bar is circular, not square-ish.
Old Apr 13, 2009 | 10:56 PM
ThumperMCS's Avatar
ThumperMCS
Just a tip for those that will be installing these....
There is no need to remove the entire torque arm as shown here...just loosen the front bolt, take the rear bolt out and rotate the arm down. Pop in the bushing insert and slide it back up, tighten bolts, you're done. Really a 5 min process!
Also, I'm probably just used to it now, but I don't notice it as much as I did when I first put it in ...oh well, I guess I'd really hate going back to stock though.
Old Apr 14, 2009 | 06:34 AM
TerryD's Avatar
TerryD
I wonder if everybody gets them from the same source and brands them. NM shows red on the web site, but specifies red (just like Madness) is not available. The point is, buy the least expensive.
Old Apr 14, 2009 | 08:42 AM
dtsoccer6's Avatar
dtsoccer6
The red is only because they want to make it easy to see when they put it in the instructions. Color really doesn't matter anyways, you never see it!
Old Apr 14, 2009 | 08:43 AM
dtsoccer6's Avatar
dtsoccer6
True, I could of done it that way, but I wanted to make it clear for people by showing a process. I for one, haven't seen an install to date and didn't know where exactly all this was. So hopefully I cleared it up for some people
Old Apr 14, 2009 | 09:13 AM
pillar's Avatar
pillar
would you suggest loctite?
Old Apr 14, 2009 | 09:16 AM
dtsoccer6's Avatar
dtsoccer6
Yeah! anything that will help loosen a tight, rusted bolt. Like I said even the air tool was having issues, it took like 4 tries for it to break loose.
Old Apr 14, 2009 | 08:15 PM
BostonR56S's Avatar
BostonR56S
nice write up!
but uh lol err steve... loctite is an adhesive, not a product to loosen tight bolts haha, just thought i'd be an *** and point it out lol, loctite will basically make it impossible to take a nut off of a bolt of applied =\
a good use for it is ssk's, such as helix's, which only has one securing bolt.
i gotta get myself one of these soon, been on my list for a long time
Old Apr 15, 2009 | 05:15 AM
dtsoccer6's Avatar
dtsoccer6
Originally Posted by BostonR56S
nice write up!
My bad people! Loctite on the bolts after you install may not be a bad idea, since I don't ever see a need to take it off again. Thanks for clearing that up Erik. I never used Loctite before and thought they made an assortment of adhesives and loosening products.
Old Apr 17, 2009 | 08:29 PM
n1tr0's Avatar
n1tr0
Hey, Loctite (threadlocker) comes in a variety of different grades and can make it easier to get a nut/bolt apart later. You can use blue/medium on just about everything, it'll prevent most fasteners from vibrating loose and keep the moisture out so they don't rust or seize together. Red is good for more critical applications, like the bolts holding your flywheel on, still not that hard to take apart, way easier than something that's rusted in place.
Old Apr 18, 2009 | 09:52 PM
dtsoccer6's Avatar
dtsoccer6
Because of this info I was able to purchase the medium and used it on my endlinks and sway bar nuts and washers. The noises I was hearing was from them! Once they were locked up, no more noise, and I didnt even use that much! Thanks for clearing this up!
Old Apr 29, 2009 | 09:02 AM
fernflex's Avatar
fernflex
I installed mine one week ago and I am also extremely happy with the product, the result and the easy it was to install it.
Old Apr 29, 2009 | 10:05 AM
dtsoccer6's Avatar
dtsoccer6
Nice!
I agree with Thumper though, once its on you get used to having it and you forget its there. Oh well, the thing is I know its there and it I can deff feel it everytime I shift. Motor on!
Old Aug 20, 2009 | 12:26 PM
sonnysu's Avatar
sonnysu
Just istalled mine this morning, The car feels much better but I have a little vibration on the pedals at idle, is this normal? any advice guys?
Greetings from Mexico
Old Aug 20, 2009 | 08:29 PM
e30r56's Avatar
e30r56
Some vibration is normal. I have the same thing.
Old Aug 20, 2009 | 08:43 PM
sonnysu's Avatar
sonnysu
thanks, I have read that with time it goes away. Lets see what happens
Old Jan 2, 2010 | 04:46 AM
Noegel's Avatar
Noegel
Just curious... did the vibration ever go away, or is it a placebo idea? As in you just get used to the vibration.
Old Jan 2, 2010 | 07:15 AM
onefish2's Avatar
onefish2
I had this installed about 2 months ago. No vibrations and definitely worth it. NM Engineering makes quality products and they were great to work with.
Old Jan 2, 2010 | 07:32 AM
countryboyshane's Avatar
countryboyshane
+1 as well. Such a great mod for not a lot of dough!
Old Jan 2, 2010 | 01:22 PM
dunphyj's Avatar
dunphyj
+1
Old Jan 3, 2010 | 10:18 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
It's nice to see some talk of this. I recommend this to every R56 customer because bang for the buck it so great.
Old Jan 3, 2010 | 02:56 PM
Faulta's Avatar
Faulta
It is great to hear customer recommendations for a company which designs and engineers functional and reliable aftermarket products.
Old Jan 3, 2010 | 04:56 PM
onefish2's Avatar
onefish2
Now isn't that interesting, that you can buy something that actually works .
Old Jan 5, 2010 | 09:30 AM
fignewton's Avatar
fignewton
Way, thanks for talking me into going ahead and getting this. I echo the benefits above, esp how much crisper the shifting is.
One note, I have the Strat exhaust, and I had to disconnect at the downpipe in order to back the rear bolt out enough that the arm would swing down. That's kinda a pain...
Fig
