R56 Engine start/stop button
The start sequence for my 09 MCS reqiures that I must have my foot on the brake pedal and the gear shift in park or neutral when I push the start buttton to start the engine. I thought I needed to follow the same procedure to stop the car. However, I find the engine will shutoff anytime I push the button without my foot on the brake and it does not matter what gear (automatic) the car is in.
Has anyone else experienced this issue?
John D.
09 MCS
John D.
09 MCS
I have an 09 MCSa with comfort access. If I remember right it won't let me turn off the engine unless the shift is in Park (never tried neutral). Don't know about on brake as my foot is on the brake when it is in gear and I just put it in park then hit the button. But if I hit the button while still in gear it does not shut off.
MC-auto and along with foot on brake, it must be in Park or Neutral to start.
Engine will stop on just a button push in Drive Gear if car is moving less then 2 mph, or not moving,
If you are moving faster than 2 mph, it ignores the start/stop button.
If you stop engine and then remove the key/fob with gearshift not in Park,
it sounds a warning chime and displays a car with arrows pointing forward and back.
On my 08 MCS automatic, I can't remove the fob after the engine is stopped unless the shifter is in Park. Yes, the engine will stop whenever the button is pushed with the engine running, regardless of shifter position. This is the first time I've given it any thought, tho. What sort of problems has that caused you?
There is nothing wrong with the button...but what purpose does it serve other than being a novelty? If it were a fob that you just keep in your pocket then I see the reason, like the Corvette....but to install the fob then have to press a button to start is strange. Its just for kicks, I understand that.
it's so convenient i want to find something similar for my garage door.
I just confirmed this morning. 09 MCSa with comfort access you can not turn off the engine while it is in gear with the start stop button. You get a warning tone and an indication in the little window the time and temp show in to put it in park.
Also, for dashiel, if you have comfort access the fob battery is not a rechargeable one like the non comfort access. It has a battery you need to replace periodically (though don't know how long they last as mine is only 3 months old).
Without the start button, how could you have a "on but not started" mode?
Inserting the fob turns on the car in an "accessory" mode (radios and lights on, ignition and engine systems off). Leave your foot off the brake and push the start button turns the car fully on and you can access all the computer set-ups like maintenance intervals and TPS system. Push the button again turns the car off. It's not something you do every day, but it is a pretty important function when you need it.
Nope...I have an 09 JCW and without putting the fob in the slot it will not start...You must have the convinience package to do that I think.
I wouldn't mind a fob for Convenience Package folk and a regular key for "Regular" people.
Personally I think the whole move towards weird fobs/starter buttons, and convenience access packages is kind of silly in general. Good ole fashioned keys still work fine and many of the modern designs have design glitches. The key/fob on my '06 Cayman was infamous for opening and closing things accidentally just from the pressures of being in your pocket.
My Honda Civic began overheating (ended up needing a new radiator) on top of Mount Lemmon here in Tucson. I had to coast down to the bottom, with no power steering (good thing it's a light car) and no power breaks (good thing I have strong legs), turning the engine on for short bursts when I'd approach an uphill stretch.
So long as the start/stop button in a manual MCS doesn't strand me on top of the mountain in a similar situation, we're cool.
I do not have the 'comfort' package on my 09 MCSa. As I recall when I bought the car in November, you had to put your foot on the brake and push the 'start/stop button to shut the engine off. I believe this procedire is outlined in the owners manual. I am only concerned because the prescribed method for shutting off the car has seemed to change and what could be next..
Many things on the Mini are computer driven. My auto up/down windows don't always respond with the auto feature. My check enigine light came on this week. With only 2k miles on the car I want to know everything is working as it should. These
I do not have the 'comfort' package on my 09 MCSa so that is not an issue. As I recall when I bought the car in November, you had to put your foot on the brake and push the 'start/stop button to shut the engine off. I believe this procedure is outlined in the owners manual. While the car starts and shuts off ok, I am concerned because the prescribed method for shutting off the car has seemed to change and is a concern to me as to what could be next.....I am 135 miles from the dealer!
Many functions on the Mini are computer driven. My auto up/down windows don't consistently respond with the auto feature. My check enigine light came on this week. With only 2k miles on the car I want to know and expect everything is working as it should. These fun little cars are not inexpensive. All the systems should work reliably. I hope to be able to get the Mini into the dealer (Keeler Mini-Albany, NY) next week to look at the 'check engine' light. I will ask them to check out the start/stop issue and window auto up/down issue at the same time and report back.
John D.
09MCSa
John D.
09MCSa
07-16-2020 12:54 PM
polotska
08-23-2015 03:03 PM
tippin
08-05-2015 08:43 AM
