R50/53 Is there difference between left and right strut top?
Old Jan 28, 2009 | 06:54 PM
pentras's Avatar
pentras
My right hand side strut is cracked. I brought an OEM but I saw there is a "L" at the end of the part no. I wonder is there difference between left and right? Am I brought a wrong one?
Old Jan 28, 2009 | 07:21 PM
Motor On's Avatar
Motor On
Usually but not *always*, the left tor right hand parts are variation part numbers or the physical part is marked.
RealOEM isn't listing part numbers but doesn't graphically make any distinction, have you compared it to the strut that is coming off?
Old Jan 28, 2009 | 07:55 PM
miminut's Avatar
miminut
From: Half Moon Bay California, 25 miles south of SF on the coast
Yes
There is definitely a difference from right to left. Right and left are mirror images of each other.
Old Jan 29, 2009 | 12:18 PM
THE ITCH's Avatar
THE ITCH
I believe that both are identical. The bearing on the stock plates is located in the center so the camber would be the same left to right. If you were installing an aftermarket camber plate like the Ireland fixed plates there is definately a right and left even though you could very easily install them on either side. That is because the bearing is intentionally set offset to give you added negative camber.
Just a side note: The Ireland fixed plates are a lot beefier than stock. Not only will they help to prevent mushrooming but the bearing carrier is from a Z4 BMW (a lot heavier car) and I have not heard of one of them failing. You would also get the benefit of a little extra negative camber in the front all with the same or better NVH.
Steve
Old Jan 29, 2009 | 05:22 PM
k-huevo's Avatar
k-huevo
They can be used on either side.
Old Jan 30, 2009 | 06:50 AM
cristo's Avatar
cristo
Alliance Member
RealOEM lists this as same left and right
http://www.realoem.com/bmw/showparts...=31&fg=10&hl=2
Old Jan 30, 2009 | 05:16 PM
pentras's Avatar
pentras
Thanks a lot.
I also found that there is no selection for left or right in online store for this item.
Old Feb 1, 2009 | 07:12 PM
pentras's Avatar
pentras
Steve
I asked Ireland, Sinec I live in HongKong, they quoted costs+shippment 180+90=$270. I brought the oem part in local shop only US$32 for one.
Anyone know which online shop is lower cost and will do surface shippment for Ireland fixed plate?
Old Feb 2, 2009 | 05:20 AM
THE ITCH's Avatar
THE ITCH
pentras
If you receive MC2 magazine you will see Ireland adds towards the back of the magazine and if you tell them that you will receive an additional discount.
TSW is also a dealer for Ireland and they are great people to work with. They may be able to help in your shipping conserns.
Steve
sevin
May 2, 2026 06:11 AM
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
xpunisherx
Aug 10, 2015 10:50 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
