cigarette lighter stuck
Old Jan 23, 2009 | 10:29 AM
drfubar's Avatar
drfubar
My cigarette lighter is stuck in the down position. If I try to pull up on it, the entire lighter assembly comes out about halfway, but the heating element stays locked in the down position.
Anybody know how to get it out of there, before I break everything?
Old Jan 23, 2009 | 03:19 PM
Eric_Rowland's Avatar
Eric_Rowland
1. Remove the fuse (left side in front of driver's door)
2. Hold socket down, pry up lighter.
The whole assembly comes out fairly easily, though it can be tough to get back together if you have the OEM auxillary gauges.
If it were me, I'd just remove the whole assembly and extract the lighter while outside the vehicle. Then figure out how it got stuck!
Old Nov 6, 2009 | 10:33 PM
drfubar's Avatar
drfubar
Hi, I fixed it originally by prying the sides, but now, several months later, the lighter is blowing the fuse constantly.
Can anybody explian or post a link as to how to remove that cigarette console. I have looked but can't find instructions.
Thanks.
Old Nov 7, 2009 | 07:03 AM
s00perc00per's Avatar
s00perc00per
Thanks.
quick fix, take out the cigarette lighter, and put in the plug from the back socket in there.
Old Nov 7, 2009 | 10:55 AM
drfubar's Avatar
drfubar
Ive tried to take out the lighter, but it only raises about an inch from the console. Is there a DIY with the removal process?
Thanks.,
Old Nov 7, 2009 | 07:37 PM
Eric_Rowland
It's just a press fit, so likely the wires are the resistance you're finding.
I don't have a DIY, but there are screws underneath the cupholders and at least one underneath the power mirror switch panel. With those out, IIRC the panel will just lift up and the wires can be accessed underneath.
Note that this is for an '04. I can't recall if the '05+ front console is different.
Old Nov 7, 2009 | 08:32 PM
drfubar's Avatar
drfubar
Excellent info!
I'm assuming the extra power outlet located in the boot is for newer models? I have an 03 MCS and have never seen the extra outlet.
I'll work on this tomorrow and get back.
Old Nov 8, 2009 | 05:30 PM
drfubar's Avatar
drfubar
Eric,
Yes, there were two screws, in in the cup-holders and two under the mirror switch. With the console lifted I was able to get the lighter out and fix it. I also bought a two way slitter at Radio Shack. All is good now.
Thanks for the info.
Old Nov 8, 2009 | 07:32 PM
Eric_Rowland
Excellent info!
The rear power outlet was in '02 and '04+ cars, but was mysteriously deleted from '03 cars. Glad to hear you're back up and running.
So did you get a new lighter or manage to fix it?
Old Nov 17, 2009 | 10:12 AM
drfubar's Avatar
drfubar
I just removed the lighter, cleaned it, bent the sides with a flat head and all good.
Having the splitter now is great. The location of the lighter is horrible for plugging and unplugging electronics.
elverado
Jan 18, 2022 02:51 AM
pglgp1292
Aug 9, 2017 12:45 PM
MINI Stupor
Oct 1, 2015 11:36 AM
Jerome R Jr W
Sep 29, 2015 11:42 AM
zsqure
R60/R61 Stock Problems/Issues
Sep 21, 2015 05:24 AM
