Headlight problem
Old Jan 18, 2009 | 06:49 AM
Luys's Avatar
Luys
Headlight problem
Hi NAM members,
Normally when I start the car, the headlight comes up and down. Today I have turned the light on I found that the lights are too down. Moreover I have turned off the car and start it again the headlight won't to come up and down. What could be the problem? and how can I adjust the headlight?
Thanks from now.
Old Jan 18, 2009 | 08:21 AM
healey67's Avatar
healey67
Is your leveling sensor plugged in?? It may be faulty or I have seen damaged wiring to the sensor. Check it out. Its on the left front lower control arm of your MINI
Old Jan 18, 2009 | 08:34 AM
Mike S's Avatar
Mike S
The motors in the headlights are broken, mine has been doing this for a while. Once in a blue moon they work and Mini do not sell the motors seperately. They only sell an entire headlight housing with it.
I opted to get the Halo Projector headlights from ebay to remedy this problem as it does not have this feature.
Old Jan 18, 2009 | 08:35 AM
Luys's Avatar
Luys
I need to lift the car to see the sensor plug is that right ?
Old Jan 18, 2009 | 08:52 AM
Luys's Avatar
Luys
Hey Mike, how could be the two motors of the headlight can be broken? Also did you buy a new headlight?
Old Jan 18, 2009 | 08:54 AM
Luys's Avatar
Luys
I have put the key and turned the key to the 2nd I hear a sound (vvviiiiii) is it the sensor plug?
Old Jan 18, 2009 | 09:00 AM
iwashmycar's Avatar
iwashmycar
i know this is gen1 but how is this sensor typically mounted?.. i was wondering if you can turn/move/adjust its mounting somehow to trick it and raise the lights....
mine cut off pretty quick on the road...too quick
Old Jan 18, 2009 | 04:38 PM
healey67's Avatar
healey67
Well if they dont self level, then I personally would just adjust them myself to the correct level you want and leave it there, why spend the money to replace if they still light up. I have not seen a motor go bad befor, not saying it can't happen.
You can see the sensor/connector by turning the wheels to the left and looking inside the front of the drivers front tire. you should be able to see the sensor and conector. There is also 3 mounting points for the inside housing of the headlamps themselves. sometimes I have seen the housing pop off the mounting post, which if the problem you can snap the 2 back together and should work ok.
Old Jan 19, 2009 | 07:39 PM
Mike S's Avatar
Mike S
Like the others have said, it could be the connector popped off or isn't on properly. I'm just giving you what went wrong with my car although it was just with the left headlight motor that gave in. I'm changing the headlights anyways so it doesn't particularly bother me anymore.
Rai1gun
R60/R61 Stock Problems/Issues
Jan 11, 2016 05:52 AM
RACEnSK8
Aug 31, 2015 01:08 PM
Lschneider
Aug 21, 2015 02:21 AM
R53Mom
Aug 17, 2015 01:38 PM
