R56 Stuck in Date/Time settings
Old Oct 11, 2008 | 06:49 PM
christianbski's Avatar
christianbski
Hi, First post and first question about me new mini. I just tried setting the 3x turn signal settings but the only thing I have available are just these options. SET DATE, SET TIME, HOME, and CHECK INFO. I Dont know how to get out of this menu! I already RTFM.
Old Oct 11, 2008 | 06:53 PM
futuremini's Avatar
futuremini
Select home. It will let you get back to the main screen and the signal settings.
Old Oct 11, 2008 | 07:22 PM
christianbski
I have already, and it exits out of menu's back to mpg/mph/temp/odometer display :(
Old Oct 11, 2008 | 07:29 PM
Benibiker's Avatar
Benibiker
I think it would help if you read the owner's manual. No, really, read it...
Old Oct 11, 2008 | 08:07 PM
RJKimbell's Avatar
RJKimbell
+1
Old Oct 11, 2008 | 08:19 PM
BCG's Avatar
BCG
Your problem is that the ignition is not on. Idiot lights, fan etc. have to be going or you can't access the area you are trying to get to.
Old Oct 11, 2008 | 08:33 PM
pilotart's Avatar
pilotart
Post #4 on THIS THREAD has good directions, pay attention to where it says "hold".
(The "Symbol" is the key w/check.)
You also need to go through it again for each key fob.
Old Oct 12, 2008 | 08:09 PM
christianbski
I did read it! That's why I said "already RTFM"
Now I'm in IT and following manuals/docs are something I do to a literal "T". I place the key fob in and starting go at it before starting the engine and all that was available was what I listed.
So it's resolved by turning the engine on. But reading elsewhere in the manual it was from my understanding that options were not available during an engine start because this would cause "driver interference" where someone shouldn't be programming while in motion or driving, well annnnyywayyys it works, go figure. Thank you for the help and input... This car rocks btw .
Old Oct 12, 2008 | 08:51 PM
pilotart's Avatar
pilotart
Well, as BCG wrote, the Ignition must be on, however if you have key fob inserted and press 'start' button without pressing clutch (or brake for auto) the engine does not start, but you can program (most) menu's, TPM reset might need engine running and you must drive a ways for it to take effect.
Old Oct 12, 2008 | 11:23 PM
Miiko's Avatar
Miiko
For some reasons beyond my comprehension, you do need to start engine in order to setup the 3x turn signal. At least, it did not work other way in my brand new Cooper S... and I could not find that clearly described in the manual either.
Old Oct 15, 2008 | 08:17 PM
christianbski
You'd think it would be the other way around. I guess I'm not the only one, well at least we cleared it up for others if they do a search.
yukinoinu
14
Jul 2, 2016 07:27 AM
Oct 7, 2015 08:52 AM
whosurgaddy
Aug 29, 2015 09:50 AM
minipopkart
Aug 13, 2015 05:22 AM
MES11
Aug 8, 2015 10:21 AM
