R52 Tire Rotation Dunlops Run Flat 16"
Old Aug 18, 2008 | 08:06 PM
bmackinlay4353's Avatar
bmackinlay4353
Gentlemen, What is the recomendation on how to rotate the above tires IE: X or front to back etc.I sure you rotate every 5000 miles. No spare involved. Bill
Old Aug 18, 2008 | 08:12 PM
mike and his mini's Avatar
mike and his mini
I rotate my tires in an X form I suppose. Front Driver to back passenger and front passenger to back driver. Also, I do it at 5,000miles or if they tread starts to become bare prior to the mileage limit.
Old Aug 21, 2008 | 11:59 AM
Trock's Avatar
Trock
The tires have directional arrows don't they? So they will have to stay on the same side of the car they were when you rotate them.
Old Aug 29, 2008 | 09:00 PM
BlueBonnet's Avatar
BlueBonnet
Back to front, at least every 5000 miles.
Old Aug 31, 2008 | 06:51 PM
bmackinlay4353
Right on Bluebonnet,Never "X" Radial tires!! Bill
Old Sep 13, 2008 | 09:00 AM
haygood's Avatar
haygood
I guess you would need two jacks, unless, like some VW's, a jack on the front jacking point can get the whole side off of the ground. I've never jacked up my MINI (in both weeks of ownership).
Old Oct 3, 2008 | 08:12 PM
BlueBonnet's Avatar
BlueBonnet
The front jacking point on each side will lift both the front and rear tire off the ground. It makes it easy to do the back to front rotation. Do it at 5000 miles so that you don't encounter the problem with having significantly more tread on the front tire than the back tire . . . you will have a little more tread on the front than the back but not enough to experience snap oversteer or the other horrors in the files of the tire corporation lawyers.
Old Oct 4, 2008 | 08:53 PM
bmackinlay4353
Rotating Mini Tires
I took your advice to rotate every 5000 miles and the jack will lift both tires on the same, side so your working on the same side and then you move to the other side !! Works like a charm even foe an old f--t like me . What happens to the TPMS indicator? Bill
Old Oct 4, 2008 | 08:59 PM
Oxybluecoop's Avatar
Oxybluecoop
Nothing will happen to the TPMS.
Old Oct 5, 2008 | 05:17 PM
erickvonzipper's Avatar
erickvonzipper
Keep em on the same side, and switch front and back.
woodstudio
Mar 15, 2020 08:28 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
TJANK
Aug 24, 2015 06:11 PM
sabjcw
Aug 14, 2015 07:40 AM
