R50/53 Rattles
Rattles
I have a 2003 Mini Cooper with 24,000 miles on it. There is a muffled rattling sound from the rear end that is driving me crazy.It is evident even on the slightest bumps. At 1st I thought it was the spare tire casing rattling. That was still removed and still the rattle. The tool box, plastic bumper, rear hatch lock, suspension, control bar etc were all checked by the dealer before the warranty expired. They acknowledged that they heard it, but could not find the cause and of course did not fix it. Any thoughts on this? It almost sounds like a muffled ball inside of a can sound. any cures outside of turning up the radio? Lots of bumps here in San Francisco. I feel like I am in Kabul.
Put some duct/electrical tape on the hatch's silver D-ring, then close the boot, drive around to see if that was it.
Speaking of Rattles
I have a rather annoying rattle on the opposite end of me car. It is in the dash, and when I start the air conditioner it gets louder but, when the air is off it only rattles when I hit a bump. I read somwhere that there is a plastic screw or somthing in there that just needs some loctite applied. Any help on this issue would be appreciated. Additionally, how hard is it to take the dash appart? Do I need one of those trim and dash board kits with all the tools that look like I'm trying to slim jim a bunch of cars?? Thanks in advance for the replies.
It is off warranty, just went off recently,but just before it went off I took it in. They acknowledged the noise and spent a day trying to find it with no luck. They heard it, tightened everything, said that nothing was loose and could not fix it. Got any other ideas?
As far as the D ring goes, It makes the noise with the hatch open. Had the spare off, Bumper cover and metal bumper off too. Still makes the sound. It sounds like something a muffled ball bouncing in a box. Muffled sound. They used there stethoscope and could not find it.
Sounds like a bad Cat ?
No, you didn't run over a cat, but the inside of your Catalytic Converter is Ceramic, and sounds like maybe there is/are piece(s) rattling around inside it......It's under warranty, have them drop it and check it.
Good Luck.
Good Luck.
I have that same bump-rattle too. I suspect my sway-bar bushings need lube. It seems to make the sound when one wheel is affected and not the other, and that means twisting the sway-bar. I keep meanint to squir some oin on them as a temporary test, but haven't yet. I do know they were well greased on install, because I was there.
torpeau
Oct 8, 2015 11:10 AM
Jim Ferrell
Oct 6, 2015 08:09 AM
eliseo1981
Sep 30, 2015 07:57 PM
Nicefeet
Sep 24, 2015 06:53 PM
