Drivetrain psi problem
Old Apr 24, 2008 | 10:57 PM
Chase's Avatar
Chase
psi problem
I just had a quick question that is probably not a quick answer. My car under normal conditions should be running 15psi with my mods. It has been running 15 psi the whole time since ive had it tuned, but a few weeks ago i saw that my car was only running 8psi. I know elevation has a little factor in that, but i should still be running around 12psi where i live. So where has the other 4psi went? Any help and advise would be greatly appreciated.:tu:
Old Apr 25, 2008 | 12:37 AM
Guest's Avatar
Guest
Some background would help. Did you change anything on the car before this happened? Does the car feel really sluggish now? What's done, what year is your car, etc.
Old Apr 25, 2008 | 09:47 AM
Chase's Avatar
Chase
I have an 04' with 89k, heres my engine mods:
K&N HAI 1540
JCW 380cc injectors
RMW tune
Invidia Exhaust
magnaflow high flow cat
obx header
m7 16% pulley
NGK plugs
Alta v.1 intercooler
And it does feel sluggish
Old Apr 25, 2008 | 10:17 AM
70spop's Avatar
70spop
Check the hose(s) to your boost gauge?
Bypass valve took a crapper? Other vacuum leak? Are you pulling as much vacuum as you used to in non-boost situations, like at idle or off-throttle?
Old Apr 25, 2008 | 10:20 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
How are the intercooler boots? Is the belt tensioner leaking from its damper?
Old Apr 25, 2008 | 11:12 AM
verveAbsolut's Avatar
verveAbsolut
Tensioner going...belt wear?
- Matt
Old Apr 25, 2008 | 01:22 PM
Chase's Avatar
Chase
the belt is pretty new, but ill check it. Ill check the intercooler boots and the gauge hose. thanks homies
Old Apr 25, 2008 | 02:29 PM
staz87's Avatar
staz87
Superchargers wear down. From what I've read on here their lifetime is an expected 100k miles. Adding a pulley may have reduced the lifetime of it.
As it ages it will become less efficient.
Just a thought
Old Apr 25, 2008 | 02:41 PM
Chase's Avatar
Chase
yeah ive thought of that too. Its funny. when one thing goes wrong it could be about 100 things that it could be.
Old Apr 25, 2008 | 02:45 PM
staz87's Avatar
staz87
Does the PSI increase linearly as the RPMS increase?
Gabe3
Tires, Wheels, & Brakes
16
Apr 16, 2016 07:55 AM
embiggenedmini
Oct 15, 2015 12:36 PM
Sep 2, 2015 09:05 AM
Sep 1, 2015 03:36 PM
PEterChoqu
Aug 26, 2015 08:33 AM
