Navigation & Audio iPhone/Bluetooth gurgling
Old Mar 13, 2008 | 06:25 PM
atit2d's Avatar
atit2d
I just picked up my MCS and paired my iphone with the bluetooth. Everything seems to have paired fine, but when I talk with someone, I have to crank the volume up high (so high that when I get an incoming call - it scares the bejeezes out of me because of the volume) and their voice cuts in and out so quickly and that it sounds like they're gurgling.
Any fixes for this??
Old Mar 13, 2008 | 09:01 PM
Bonk!'s Avatar
Bonk!
Had the same problem. I turned off WiFi then re-paired Mini with iPhone, and it works fine now.
Old Mar 14, 2008 | 09:40 AM
COOP310's Avatar
COOP310
Definately caused by the WiFi. I only turn mine on when I need it now.
Old Mar 14, 2008 | 10:57 AM
nicknbecka's Avatar
nicknbecka
Interesting, I wonder if the WiFi in the newer Blackberrys causes the same problem?
Old Mar 14, 2008 | 03:43 PM
atit2d's Avatar
atit2d
Yup, that took care of it. I didn't even have to re-pair the phone - just turned off the WiFi. THANKS!!!
Old Mar 28, 2008 | 08:42 AM
stealth's Avatar
stealth
I've got the exact same problem, I'll try this fix today.
Old Mar 28, 2008 | 10:10 AM
geekswrath's Avatar
geekswrath
It will fix it, did for me.
Old Apr 1, 2008 | 08:08 AM
COOP310's Avatar
COOP310
Most likely. The interference problem is one with the technologies of Bluetooth and WiFi, not one with the iPhone/BB and/or MINI.
Both Bluetooth and WiFi operate in the 2.4Ghz band (along with microwaves, cordless home phones, wireless USB, and zig-bee devices). Bluetooth uses 79 channels and the frequency-hopping spread spectrum (FHSS) technology in that band while WiFi uses 13 channels and the direct-sequence spread spectrum (DSSS). Bluetooth relies on its frequency-hopping algorithm to avoid the majority of interference from WiFi, but a single active WiFi network (in this case the one being run by the iPhone or BB) can cause heavy interference on alot of the Bluetooth channels. This is what causes the dropouts that you are hearing on the calls.
Confusing, maybe, but this is the simple version. I hope it helps.
Old Apr 1, 2008 | 08:50 AM
nicknbecka's Avatar
nicknbecka
Nope, not confusing at all- a great summary, thank you! Also, bonus points for including zig-bee
Old Apr 3, 2008 | 06:04 AM
stealth's Avatar
stealth
Yep - turned off wi-fi and bluetooth once again works. Thanks!
Old May 7, 2008 | 03:48 PM
Swucker_Barnhue's Avatar
Swucker_Barnhue
I had the same issue with the volume. When I turned up the volume to hear a caller, the next time the phone rang it would be *way* loud. A trick I learned was to just turn down the volume at the end of the call, before you push the "end" button. That way when someone calls you, you will not have to change your underwear at the next rest stop.
dangsdunks
Jul 7, 2014 08:48 PM
mwittstock
Jun 17, 2014 05:17 PM
SkaBob
Jun 24, 2011 09:41 AM
mikesminicooper
Aug 1, 2008 07:24 AM
mikesminicooper
Jul 30, 2008 10:49 PM
