R56 Gurgle on startup
Old Jun 17, 2014 | 01:08 PM
mwittstock's Avatar
mwittstock
Gurgle on startup
There is so much information out here, I am sure this has been talked about. I purchased a 2009 MCS with 30k on it. It has had the recall performed on it for the timing chain and I just changed the oil at the dealer. Before the oil temps reaches 100 to 105 degrees (ScanGauge II) the engine makes a very gurgle or bubble sound.
Normal?
Old Jun 17, 2014 | 05:17 PM
ashchuckton's Avatar
ashchuckton
Sounds like you have air trapped in the cooling system. Most likely you are hearing the air move through the heater core. Open the hood & check the coolant level. Add if needed. Do this on a COLD engine.
Teh
Jun 13, 2018 02:59 PM
jennster
Sep 28, 2015 06:19 PM
Sep 8, 2015 11:37 AM
bwirtz
Aug 29, 2015 05:38 AM
karvinbass
May 4, 2006 04:35 AM
