P0073 Error code?
Old Mar 8, 2008 | 11:44 AM
Minidrivr's Avatar
Minidrivr
P0073 Error code?
I hooked up my new Scangauge II today and it read out this code. Found on Mini2 it means, P0073 Ambient Air Temperature Sensor Circuit High.
So what does that mean? Car runs fine and temp display is normal.
Last edited by Minidrivr; Mar 8, 2008 at 12:30 PM. Reason: Transposed Error Code Numbers
Old Mar 8, 2008 | 11:50 AM
AlexMoultonIsMyMan's Avatar
AlexMoultonIsMyMan
It means:
P0037 HO2S Heater Circuit Low Voltage Bank 1 Sensor 2
Now, what that means I have no idea.
Old Mar 8, 2008 | 12:22 PM
Minidrivr's Avatar
Minidrivr
Sorry Alex, I got the numbers backwords. It's P0073.
I edited the original post.
Old Mar 8, 2008 | 03:14 PM
Guest's Avatar
Guest
More than likely it means your Ambient air temperature sensor is malfunctioning . I'm pretty sure any DTC will be talking about something engine related, not the OBC Temperature display. The engine has sensors to measure ambient air temp.
Old Mar 8, 2008 | 05:13 PM
Minidrivr's Avatar
Minidrivr
I had the front bumper repainted. I wonder if they moved the car after removing the bumper and had the sensor disconnected. Maybe that stored a code. It seems to be working just fine, reporting the correct temperature.
Old Mar 9, 2008 | 08:03 AM
djam43's Avatar
djam43
Disconnect the battery for a bit and see if it will reset.
Old Mar 9, 2008 | 09:56 AM
Minidrivr's Avatar
Minidrivr
The Scangauge will let you reset it. I'm going to see what my SA says and then will reset it and see if it comes back.
Old Mar 9, 2008 | 01:21 PM
MotorMouth's Avatar
MotorMouth
you might not want to let your SA know you have the scanguage.
Old Mar 9, 2008 | 01:34 PM
ENGINE 58's Avatar
ENGINE 58
if you can let us know what the code was and what caused it. im wondering if my homemade cai has gotten any filter oil on my maf sensor and maybe that could have caused my cel when i had the alta pnp on my car. the cel has gone away but i had to take off the pnp to make it reset. im going to get a scan gauge in a couple of weeks , when the moneys there.
Old Mar 10, 2008 | 11:07 AM
VelvetFoot's Avatar
VelvetFoot
Have you guys tried to access your codes via the trip computer? I just accessed mine and it said it was "OK", but it'd be interesting to see if you can extract the real BMW error codes right from the dash.
https://www.northamericanmotoring.co...d.php?t=131669
Old Mar 10, 2008 | 04:52 PM
Minidrivr's Avatar
Minidrivr
It doesn't affect the car from what I can see. I don't see why it would make any difference if they knew about it or not. Does every one remove their Alta gauges and pods when they go in for service to hide them? At least the scangauge doesn't need any modifying of the car like Alta's gauges do.
I tried that but it says everything is "OK."
Old Mar 11, 2008 | 04:55 AM
VelvetFoot's Avatar
VelvetFoot
Well, "OK" then! That's a good sign!
Old Mar 11, 2008 | 01:21 PM
MotorMouth's Avatar
MotorMouth
Don't say I didn't warn you if you let them know you've been reading and clearing codes.
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
hamptup
R55 :: Clubman Talk (2008+)
18
Nov 29, 2016 05:04 PM
MiniSkoon
Sep 9, 2015 12:40 PM
MasterShaftner
Sep 4, 2015 03:52 PM
