JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW JCW Carbon Fiber Rear Door Handle Install?
Old Feb 27, 2008 | 04:44 PM
maximusGeek's Avatar
maximusGeek
Has anyone installed the JCW CF rear door handle them selfs? How hard is it? I hear the mirrors and hood scoop are not very difficult.
Old Feb 27, 2008 | 04:52 PM
flaco's Avatar
flaco
it is very easy...just plug it in and screw it on
Old Feb 27, 2008 | 06:08 PM
umterp08's Avatar
umterp08
Yeah it was incredibly easy. Theres only 4 torx screws in plain sight. No hassle at all.
Old Feb 27, 2008 | 07:16 PM
ghosthound's Avatar
ghosthound
i would say the mirror and hoodscoop are harder than the boot handle... but they are not "hard." I find it easier to unscrew a screw than to pry snap connectors because i have a tendency to break those quite easily.
Old Feb 27, 2008 | 09:05 PM
ScottRiqui's Avatar
ScottRiqui
The only potential "gotcha" for installing the rear hatch handle is that some cars have more slack in the electrical wiring then others. On some cars, you can pull the wiring out enough so that the quick-disconnect plug is outside of the car's body, while other cars don't have as much slack, so you have to reach *inside* the body panel with either skinny fingers or needle-nose pliers to unplug the connection.
Other than that, the swap is trivially-easy.
Old Feb 27, 2008 | 10:23 PM
maximusGeek
Thanks for all the responses!
Old Aug 7, 2008 | 07:43 AM
jasonite's Avatar
jasonite
So if I were to order this (and the bonnet scoop) from my dealer, does anyone know whether the parts would come with installation instructions?
Old Aug 7, 2008 | 07:06 PM
masterd78's Avatar
masterd78
MANIAC
I got my hood scoop from the dealer and the rear handle from outmotoring.com and they both had instructions. It was supppppper easy to install the rear handle.
Old Aug 8, 2008 | 04:14 AM
jasonite's Avatar
jasonite
Cool! Thanks so much, masterd78 and everyone else. Very helpful info
Old Jun 6, 2010 | 07:22 PM
mynnDAWG's Avatar
mynnDAWG
hi guys, tried to install mine last wekened but seems there's something wrong with the wiring :(
after connecting the wires, seems the lock doesnt work...do i need to reprogram back or connect/reconnect the battery terminal as well???
Old Oct 5, 2013 | 04:45 PM
BC_Rob's Avatar
BC_Rob
How'd it go.
I'm about to install it. Did you get the lock working. Any tips to share?
minimofo
Factory JCW Talk (2009+)
130
Oct 14, 2016 06:14 AM
marendt428
Feb 25, 2016 07:13 AM
marendt428
Aug 9, 2015 06:54 PM
OutMotoring
Aug 6, 2015 09:32 AM
