R56 Drivers Side Window Streaking...
Old Dec 30, 2007 | 08:02 AM
kevinminict's Avatar
kevinminict
My Drivers side window on the inside is streaking the whole length of the window form top to bottom.
I open my drivers side window daily to get into/out a parking garage and I notice on the inside of the window towards the rear and front sections its wet and dirty once it gets rolled up a wet streak from top to bottom
I dont know if precipitation and salt (from recent snow) got into the window when it was rolled down..... How do I fix this? Its been like this for almost 2 weeks and has not dried out....prob bc I keep the window rolled up.
Should I roll my window down and use a hair dryer to try and dry it or is this wetness more down inside the door....I dont know if there are any more felt strips inside the door o just on the top.
The innter felt strip (below in first photo) is what I think is causing the problem....any suggestions? Maybe if it dosent fix it take it to MINI and have them replace it?
Photos:
#1: http://farm3.static.flickr.com/2037/...3091c1e7_o.jpg - Inner Felt Strip
#2: http://farm3.static.flickr.com/2308/...bd708aec_b.jpg - Streaks on Window
Thanks for your help...
Old Dec 30, 2007 | 04:20 PM
r56mini's Avatar
r56mini
Mine gets that too.
Old Dec 30, 2007 | 04:24 PM
ENGINE 58's Avatar
ENGINE 58
yeah i get that crap too . i tried waxing the inside of the window and it takes a lil longer to start doing it again. i also keep a towel in the car to wipe it away when i see it.
Old Dec 31, 2007 | 06:37 AM
piccolo's Avatar
piccolo
same thing for me...i hate it after its clean
Old Dec 31, 2007 | 07:01 AM
MiniJayhawk's Avatar
MiniJayhawk
Ditto. Looks to be a design flaw. I understand it happening on the outside of the glass after a rain or car wash, but it shouldn't happen on the inside.
Old Dec 31, 2007 | 07:08 AM
CHKMINI's Avatar
CHKMINI
Your window is streaking? It had better get its clothes back on before it gets arrested
Old Dec 31, 2007 | 07:12 AM
MiniJayhawk
California and Arizona potholes?!?!?!? You guys crack me up. Come to Kansas City sometime. You could lose an entire Mini in some our our potholes. I bet the northern guys would even be laughing at me. They lose Hummers in their potholes.
Old Dec 31, 2007 | 07:23 AM
chili_red07's Avatar
chili_red07
I get the window thing too... and yeah, come check out the potholes in Mass
Old Dec 31, 2007 | 11:39 AM
bmbleB07's Avatar
bmbleB07
the best cure for a screaky window is a bit of wd40 to lube it up. what i do is spray a bit into a paper towel and (with the window down) wipe the sides. The window journals inside the door can be lubed with access that is powered down using the window. good to go
Old Dec 31, 2007 | 11:44 AM
MiniJayhawk
Our windows don't screak, they leak on the inside edge of the door somehow so that when you roll the window down after rain/snow/carwash it leaves a streak on the inside. Outside is expected, but not on the inside.
Old Dec 31, 2007 | 11:57 AM
MCS06's Avatar
MCS06
I know this is for model year '07; however, I have a friend
with an '06 that had the same problem on driver's side
window. Still under warranty, she went to the dealer earlier this year
and had it repaired. No problem since. But, now her passenger
side window is doing the same thing. She'll be returning to the
dealer soon. Hope this helps. Sorry, can't recall what the dealer
said the problem was.
Old Dec 31, 2007 | 12:21 PM
kevinminict
Update: I took a hair dryer and with the window rolled down I dried the inside felt trim piece and its cured the problem, so far. I think it got wet on the inner most felt strip on the inside of the window from snow etc. and it didnt dry because its been so cold and damp. In the summer it does this but allways dried.
woodstudio
Mar 15, 2020 08:28 AM
RACEnSK8
Aug 31, 2015 01:08 PM
Russter500
Aug 26, 2015 12:11 PM
StuRat
Aug 25, 2015 05:27 AM
messyjesse96
Aug 12, 2015 05:51 AM
