Is anyone running 37mm offset?
Old Dec 2, 2007 | 04:06 AM
jeffc's Avatar
jeffc
7th Gear
I found a set of rims that I like but the offset is 37mm and was wondering if anyone out there is running this offset.
If you are running 37mm offset:
-Do you have any rubbing?
-Is your car lowered?
-Did you have to do any mods?
-What size tires are you running?
Thanks in advance
Old Dec 2, 2007 | 07:05 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
I am, but due to 8mm spacers. My Kosei K1s are 45mm offset but I have 8mm concentric spacers all round. The car is lowered and I have no rubbing at all. In fact, the fronts could handle 12mm spacers, so could go 33mm offset without problems I'd bet.
But perhaps wheel offset and effective wheel offset are two different things?
cheers,
Old Dec 2, 2007 | 07:22 AM
jeffc's Avatar
jeffc
7th Gear
How much is your car lowered?
thanks,
Old Dec 2, 2007 | 07:32 AM
minimusprime's Avatar
minimusprime
et 37 oz ul's 5mm spacer up front 205/45/17 tires
lowered on hsports
2 degrees front camber 1.5 degrees rear camber
no rubbing.
Old Dec 2, 2007 | 08:29 AM
jeffc's Avatar
jeffc
7th Gear
Thanks Minimusprime...
Old Dec 2, 2007 | 08:36 AM
Darkness's Avatar
Darkness
lowered on hsports
no rubbing.
So you brought the et up from to 32? Do you have to add the spacer in front so as not to rub? I want to do 215/40/17 but it's not looking good
Old Dec 2, 2007 | 10:27 AM
WC50 408's Avatar
WC50 408
I had a set of OZ UL with Goodyear FI 215/45/17 and had NO issues at all. I had them on a GP and it has the JCW lowered suspension. No spacers just bolted them up and drove.
Old Dec 2, 2007 | 10:35 AM
jeffc's Avatar
jeffc
7th Gear
What was the offset on the OZ UL?
Old Dec 2, 2007 | 01:18 PM
minimusprime
yeah effectivly i'm running et32 in front. I had to do it to clear my stoptech brakes. I think i could run a 215/40 without any problems. If i did have any rubbing it would be very slight.
Old Dec 2, 2007 | 05:57 PM
WC50 408's Avatar
WC50 408
The OZ Ultraleggras I ran had an ET37 and I ran the Goodyear F1 GD-S3 in 215/45/17.
Old Dec 8, 2007 | 06:17 AM
jeffc's Avatar
jeffc
7th Gear
Is your car lowered? I am still not sure if I should buy the Wheels I want with the 37 offset.
Old Dec 8, 2007 | 07:33 AM
vdubdoug's Avatar
vdubdoug
Rubbing has allot to do with tire size. I had a set of 17x7 oz Superleggera's with an et 37 and they rubbed all day and every day till i cut the inner fender liner. Wheels with an ET 37 will look great but be carefull not to have too wide a tire and you or will have problems.
Old Dec 8, 2007 | 07:49 AM
jeffc's Avatar
jeffc
7th Gear
How hard was it to cut inner fender liner and did you have to do it on all 4? Is your car lowered? Also what tire size do you have and any pictures.
Old Dec 8, 2007 | 08:43 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Just to make sure....how wide are the wheels you're talking about? Doesn't seem to be given....
Old Dec 8, 2007 | 12:07 PM
jeffc's Avatar
jeffc
7th Gear
17x7
I ordered them Lets hope they fit without cutting.
Old Dec 9, 2007 | 07:37 AM
DrPhilGandini
Im pretty confident you'll be OK, jeffc. I run 215/40/17s although they are RT615s which are a little lower in profile than other tires. My car is pretty slammed. I have no idea how much lower than stock as that varies considerably from car to car, but I have about 1/2" clearance between wheel and well when looking side on. I also run COs with little travel.
I think I could run 12mm spacers in front with no problems.
Old Dec 9, 2007 | 01:27 PM
jeffc's Avatar
jeffc
7th Gear
I will post some pictures on next Sunday. I should have them by Wednesday and plan on putting them and the new stud kit on Sunday. I will then take them off until spring but want to make sure there are no issues and I want to see how they look
Here is a picture
Old Dec 9, 2007 | 01:30 PM
kenchan's Avatar
kenchan
^^ they should look nice. specs?
Old Dec 9, 2007 | 01:41 PM
jeffc's Avatar
jeffc
7th Gear
17x7 - 21lbs - 37mm Offset - With Yokohama Parada Spec-2 - TSW Stud Kit
Broke a 1000 Post - WOOT
Can't wait.
Old Dec 9, 2007 | 06:03 PM
jhiggs26's Avatar
jhiggs26
I've got Alta springs with 17" by 7" OZ ULs(stock rubber) and no rubbing even when pushing hard autocrossing. I've got stock camber up front and at the rear.
Enjoy the new wheels this spring Jeff!
Jeremy
Old Dec 9, 2007 | 10:23 PM
terryg's Avatar
terryg
Can't wait to see them at the dragon!
Old Dec 10, 2007 | 03:45 AM
jeffc's Avatar
jeffc
7th Gear
Hey you staying at Bluemountain again? If so see ya there.
How did you make out with the Tickets?
Old Dec 10, 2007 | 07:53 AM
txwerks's Avatar
txwerks
I'm running 16x7 OZ Ultralegerras with a +37 offset... With a 225/45R16 and a 1.5" drop, I had to do a bit of trimming to make it work. With a 205/45R16, there was no rubbing...
Old Dec 12, 2007 | 04:23 PM
jeffc's Avatar
jeffc
7th Gear
Ok here is a preview. Wheels came in today.
madmax88
Oct 26, 2015 01:45 PM
actualsize37
Sep 1, 2015 06:43 AM
jwildr56
Aug 26, 2015 12:40 PM
TOMSR53
Aug 26, 2015 10:18 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
