Navigation & Audio JL Audio Cleansweep Volume Control
Old Oct 8, 2007 | 11:39 AM
cinci4u's Avatar
cinci4u
I will be installing a JL Audio Cleansweep in my 2007 Mini S in the next few weeks. I was hoping for suggestions on the placement of volume control for the Cleansweep unit. It is very important to me that I keep the stock look of the car. Any help will be great.
Old Oct 8, 2007 | 12:44 PM
PGT's Avatar
PGT
I'd suggest somewhere that falls easily to hand, somewhere near the shifter or armrest. I did this in my Subaru and it became much more intuitive to use than the volume control up high in the dash
Old Oct 8, 2007 | 12:53 PM
ScottRiqui's Avatar
ScottRiqui
^ +1
If there's an unused knockout panel anywhere near the shifter or brake handle, that would be my first choice. That way, if you ever remove it, you just need to replace the knockout panel and there won't be a hole left behind.
Old Oct 8, 2007 | 01:21 PM
PGT's Avatar
PGT
here was my setup in the LGT (left is volume, right is bass controlling the JL 500/1)...I'd have to see an R56 again to suggest a good spot, though I think there's something near the e-brake
Old Oct 8, 2007 | 07:11 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Hey guys: I have been using the Clean Sweep in my MCS for a few months now. I have been able to avoid using the volume **** included with it in most cases and use just the volume on the MFSW or the dash. Seems to work really well. I only use the CS volume to really trim things on a certain song etc.
Going back to the question, the volume and LED in my car are mounted in the console, just behind the shifter. I used the supplied polished **** to help match the interior. This placement falls at hand very nicely!
Side note. This product is REALLY nice. There are other options but I seriously recommend this one!
Old Oct 8, 2007 | 07:17 PM
PGT's Avatar
PGT
if you are using system volume and not the CS volume, you're wasting your money buy a proper LOC and be done (and send me the $200 difference).
The CS does two things - 1) it delivers a clean, low-level RCA output from a speaker level input - it can output as much as 8 volts RMS (like a hi-end head unit). 2) It also takes out any volume dependent factory EQ from the stock head unit to give you a flat frequency response to build on.
Using the system volume control obviates the second function. Period. No arguing about this one...it's the nature of the purpose of the CleanSweep. Think about it....the stock system is making up for less than admirable performance out of the basic speakers. You've put in a nice aftermarket set that don't need bass and treble boost to sound good.
Old Oct 11, 2007 | 02:53 PM
ghosthound's Avatar
ghosthound
if you use the CS and connect an ipod to it, does the screen display the info? i would assume not.
Old Oct 11, 2007 | 03:52 PM
PGT's Avatar
PGT
what screen? the CS has audio in only, not an iPod connector, thus you use the iPod itself to choose music
Old Oct 11, 2007 | 10:05 PM
ghosthound's Avatar
ghosthound
i meant on the oem display but i guess that answers my question
Old Oct 14, 2007 | 06:43 AM
a96bimmerm3's Avatar
a96bimmerm3
FWIW, i have a rockford fosgate 360.2, and the oem signal was pretty flat... I think something like an audiocontrol LC8 or LC6i would work great and cost way less than the cleansweep or anything else. I also grabbed the signals going into the amp, they work fine for me.
Filmy
15
Jun 6, 2023 06:27 AM
Filmy
Sep 7, 2015 08:27 PM
Sailorlite
Sep 4, 2015 07:03 PM
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 11:15 AM
