TPMS beep?
Old Oct 4, 2007 | 09:29 PM
tomah's Avatar
tomah
TPMS beep?
ok guys, im contemplating not swapping over TPMS from my R56 bridge spokes onto my volks. question is... will the TPMS constantly beep? or does it just beep like when i start the car and it wont beep again?
Old Oct 5, 2007 | 09:22 AM
tomah's Avatar
tomah
zuh?
Old Oct 5, 2007 | 11:46 AM
kenchan's Avatar
kenchan
not sure... but usually some beeping and the check light will be constant.
then the motor shuts down after 5miles permanently.
Old Oct 5, 2007 | 12:15 PM
Wake|MCS's Avatar
Wake|MCS
LMAO...
Why not just put them on the Volks? Takes less than 5 minutes for all 4 with the tires unmounted...
Old Oct 5, 2007 | 12:18 PM
tomah's Avatar
tomah
im getting low on moneys, plus my volks already have tires on, so that would mean double unmounting :T
Old Oct 5, 2007 | 12:29 PM
Wake|MCS's Avatar
Wake|MCS
Gotcha... To answer your question, I'm not sure at all but I would think it won't constantly beep. The warning symbol will just always be on. My friend doesn't have the sensors on his Range Rover Sport and he just gets the warning symbol and the beep when he first turns the car on...
What Volks did you get?
P.S.: FYI, you don't have to unmounted the tire to take the sensor off, nor put it back on. At our shop we learned to just break the seal and use the machine to drop the tire a bit right where the valve stem is. Giving you enough room to take it off and put a new valve stem in place. I think Volks accept the TPMS sensors just like factory wheels so you could look at that option...
Old Oct 5, 2007 | 01:07 PM
tomah's Avatar
tomah
awesome thanks for the info! btw i got some volk te-37's powdercoated solid glossy black. if i get the wheels on soon, ill be able to take some pix
Old Oct 10, 2007 | 06:39 AM
aem421's Avatar
aem421
I have the new TPMS on my car. There is no beeping. The tire symbol will light up on the speedometer. It's the first light of the eleven. You will also get a symbol on the tach. It's a triangle shape with an exclamation mark inside.
I would just swap over the sensors to the new wheels. Most places can do it for like $2.50-5.00 per wheel.
Old Oct 11, 2007 | 09:31 AM
tomah's Avatar
tomah
awesome. yea looks like im gonna have to go to americas tire and have them swap out the TPMS. i have to do lug stud conversion in the parking lot adjacent to americas tire cuz they said they will not mount the tires on my car with wheel studs.
Old Oct 11, 2007 | 11:02 AM
<MINI>'s Avatar
<MINI>
Are you doing the lug/stud conversion because the holes are too small in the new wheels? If so, just drill the holes out with a 9/16" drill bit. Not much material has to be removed for the stock lug bolts to fit.
Old Oct 11, 2007 | 12:14 PM
tomah's Avatar
tomah
i figured it would be easier for me to sell my volks, if i ever needed to, if i kept them M12 sized. believeeeeeee me, it took a lot of contemplating on my part as far as what i should do. plus the wheels are powder coated and if i were to drill into them, im sure the powdercoating would crack
freckles81
Jan 15, 2017 06:33 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
Doc Pain
Sep 15, 2015 11:31 PM
PSU 98
Sep 11, 2015 11:20 AM
renchjeep
Sep 6, 2015 01:54 PM
