R56 Momo Shift Knobs
Old Sep 27, 2007 | 01:45 PM
byhsu's Avatar
byhsu
Momo Shift *****
I would like to change the shift **** of the MCS for something not so bulky, like a Momo Combat Evo, is this possible? Has someone done it before?
Old Sep 27, 2007 | 03:43 PM
Robin Casady's Avatar
Robin Casady
There are a few optons for the manual transmission on the MINI. If you want a stainless steel or billiard ball shift ****, the Whalen Shift Machine is the thing to get. http://www.whalenshiftmachine.com/
He does custom engraving on the stainless steel ***** and has some with inlaid stone. I use his adaptors to make wooden shift *****.
Old Sep 27, 2007 | 04:09 PM
byhsu's Avatar
byhsu
Will a MOMO brand shift **** work? I kind of like the design of the Combat Evo carbon
Old Sep 27, 2007 | 04:28 PM
masterd78's Avatar
masterd78
MANIAC
I honestly can't say for sure, but I would say why not? I have a momo shift **** that has gone through two different cars. It just uses hex screws to hold tight to the shifter. So it is like a "one size fits all" type ****.
Old Sep 27, 2007 | 05:29 PM
motormini04's Avatar
motormini04
This maybe a silly question but I'm new to Mini ownership... I've seen a few posts about changing the Manual shift **** but does anyone know if they make any good aftermarket Automatic shift ***** for the Mini?
Old Sep 27, 2007 | 05:33 PM
Xray'dit_Mini's Avatar
Xray'dit_Mini
+1 for the Whalen!!!!!!
You can pretty much have whatever your heart desires!
I have had many other shift *****, several MOMO, but Whalen is the best by far!!!
Old Sep 27, 2007 | 05:34 PM
justintime's Avatar
justintime
I use a sparco, you just use the little screws. it fits like a champ. I'd imagine momo is the same
Old Sep 28, 2007 | 10:31 AM
cinellipro's Avatar
cinellipro
Procedure for Installing Shift ****
Hi. Is there a special method or tool needed to remove the factory shift ****? Thanks in advance.
R
Old Sep 28, 2007 | 11:32 AM
Modnar's Avatar
Modnar
Pull on it straight up really hard, and be careful not to hit yourself in the face (or any other sensitive areas).
Old Sep 28, 2007 | 11:38 AM
byhsu's Avatar
byhsu
So the Momo Shift **** would just attach to the shifter via screws? Does the Whalen **** attach in the same way? with screws?
Old Sep 28, 2007 | 11:46 AM
aem421's Avatar
aem421
I had the Momo shift **** on my WRX. The first one was universal. The second one was actually made for the car. The universal one just pushes straight down over the shifter and is held in place by two/three set screws that you tighten directly into the shaft with the supplied allen wrench. That's what holds it in place. Mine worked fine until they came out with one that actually screwed right onto the shaft. They are nice shift *****.
Old Sep 28, 2007 | 11:48 AM
MLPearson79's Avatar
MLPearson79
The Whalen ***** have a sleeve that lifts up and then as you slide it onto the shifter you let go of the sleeve and it clicks into place.
Old Sep 28, 2007 | 02:01 PM
Robin Casady
If you are familiar with the quick-release mechanism on compressed air hoses, the Whalen adaptor works in a similar manner. A stainless steel sleeve slides up allowing six tiny ***** to retract. You then slide it onto the shift lever shaft until a plastic cross rod snaps into the slot on the shaft. Releasing the sleeve than causes the ***** to protrude into the groove on the shaft, holding it in place.
The adaptor is machined from stainless steel and very nicely done. It is a lot more sophisticated than set screws and is specifically designed for the shaft on the MINI. Most other cars use threads on the shaft. So a universal adaptor is not going to be ideal for the MINI.
Here is a photo of the Whalen adaptor that I use in wooden *****. He uses this with his billiard ball *****. The brass piece is glued into the billiard ball or wooden **** and threads onto the stainless steel adaptor.
The adaptor slips over the MINI shift lever shaft. A plastic cross rod snaps into the notch on the MINI shaft.
This is what one of my ***** looks like. In this ****, the adapor is almost completely hidden. You would put the adapor on the shift lever shaft, then screw the **** on.
The Whalen stainless steel ***** are press-fit onto the stainless steel adapor, rather than threaded. So, the adaptor becomes part of the ****. You would put them on the same way you put the adaptor on.
OutMotoring
Mar 3, 2017 06:29 AM
gar56
Nov 15, 2016 06:41 AM
bahman
Sep 30, 2015 01:59 PM
aldito2
Sep 30, 2015 10:44 AM
kevinlhr310
Sep 27, 2015 02:31 PM
