Drivetrain in search of QUIET freeflow muffer
Old Sep 19, 2007 | 10:02 AM
sonichris's Avatar
sonichris
i know... there is no such thing. BUT, i'm tired of advertizing. my milltek resonator is blown out and with the header, my car is VERY loud. i'm looking to replace the resonator with a performance muffler that quiets the sound down as much as possible, without hindering exhaust flow.
please no posts telling me to put the stock system back on, i just want a universal fit muffler (2.5" inlet and exhaust) that will fit.
thoughts on magnaflow, dynomax, spintech, or others that i haven't heard of?
Old Sep 19, 2007 | 09:40 PM
Chase's Avatar
Chase
Im kinda in the same boat with you man. i have a single muffler custom system. I need to replace the muffler i have and add a resonator, so any input would be great.
Old Sep 20, 2007 | 07:07 AM
sonichris's Avatar
sonichris
aero exhaust
anyone had any experience with aero exhaust? what about borla universal fit? anyone? bueller?
Old Sep 20, 2007 | 04:08 PM
Longboard110's Avatar
Longboard110
I have a Borla Pro xs muffler sitting in my garage im going to be putting on this fall, Ill post when its all put together
Old Sep 21, 2007 | 02:23 PM
ClintTheMiniOwner's Avatar
ClintTheMiniOwner
I have tried multiple mufflers and arrangements with my car and it has driven me crazy. This is what worked for my mini,
Two magna flow 16'' in line resonators and a dual 2 1/4 three chambered magnaflow muffler setup with the outlets firing into each other with an outlet out the side of the pipes where they connect out the back of the car. i will try and get a pic for you. I also found that if you have any header, a quiet rig is almost impossible. It might be in your best interest to put the stock one back on and remove the pre-cat. I find that to be the best for sound and very important, driveability. Also a giant blanket in your trunk can quiet things down in the cab for those long road trips.
check out this link to see magnaflows similar design and enlarge the pic- http://www.planetmagnaflow.com/shop/...-15742-49.html
Its kind of like this but with three chambered mufflers and an extra resonator. I know it sounds like alot but hey, its a 1.6!!! and a fast quiet mini is really hard to achieve.
Old Sep 21, 2007 | 03:26 PM
sonichris's Avatar
sonichris
i understand that a truly quiet system will be impossible with a header/race cat. i'm trying to get as quiet as "possible" without losing flow. i want to stay away from chambered mufflers unless they were big enough. i think what you are describing is close to one design i've come up with.
i was thinking of replacing each of the mufflers on the rear section with chambered mufflers (like the magnaflow XL or dynomax super turbo) of at least 2" ID. the pipes on the milltek are 1.75 each on the rear section, so i don't think would lose any flow back there. then i would find the biggest straight through muffler i could fit right behind the cat.
i will probably do the straight through muffler first and see what that does before doing the rear section. lucky for me, i have an extra milltek rear section to play with.
is that similar to what you have, or did you use ONE dual outlet magnaflow XL with two pipes coming out of it?
Old Sep 21, 2007 | 04:41 PM
MarioKart's Avatar
MarioKart
Vendor
I have had about 6 exhaust and I'm the happiest with the Borla Sport. Its not the best looking but it got me good dyno numbers and my girlfriend approves. When I go the head and cam my car became crazy loud. Borla makes a race and sport. Bola says they flow the same it is just a sound difference.
Mario
Old Sep 22, 2007 | 06:13 AM
sonichris's Avatar
sonichris
i googled borla and came up with a "street" and "sport" system that borla makes for the mini. the "sport" is also know as the "race" version. so do you have this one:
or this one:
Old Sep 22, 2007 | 10:13 AM
MarioKart's Avatar
MarioKart
Vendor
or this one:
I have the bottom picture. The top pic was way too loud
Old Sep 22, 2007 | 10:17 AM
Longboard Mini's Avatar
Longboard Mini
Thanks again Mario, It's in the mail.
Bryan
Old Sep 22, 2007 | 12:17 PM
MarioKart's Avatar
MarioKart
Vendor
Bryan
no problem, ejoy the ride and the UFC fight. I will watch it on payper view
Old Sep 22, 2007 | 04:41 PM
ClintTheMiniOwner
I got two 2 1/4, three chambered magnaflow stainless mufflers =)
Old Sep 22, 2007 | 05:51 PM
k-huevo's Avatar
k-huevo
CTMO, how about a part number for the chambered mufflers please? I don't see any chambered mufflers listed on the link in post#5. What diameter straight through muffler fit in the rear heat shield channel?
Old Sep 23, 2007 | 04:12 PM
jaynicholson's Avatar
jaynicholson
Did you like your Milltek? If so, unless you bought it used, it has a lifetime warranty. Just a thought.
Old Sep 23, 2007 | 08:41 PM
sonichris's Avatar
sonichris
i emailed them (stratmosphere) this weekend, should hear back monday. if it does have a lifetime warranty i will certainly get the resonator replaced. i really liked the sound of the milltek. it slowly got louder over the 3 years i had it, but not bad enough to replace. but now that the header is on, it's just too much. i pretty much have a straight pipe and two teeny mufflers in the back.
i tried searching stratmophere's website and did not see any warranty info on it, that's why i emailed asking what the warranty was. do you remember where you saw that it was a lifetime warranty?
Old Sep 23, 2007 | 08:56 PM
jaynicholson
http://www.millteksport.com/exhaust.faqs.cfm
Also, I live 20 min. from Stratmosphere and have asked them about it a few time over the phone and in person.
Old Sep 25, 2007 | 09:43 AM
thatatvguy's Avatar
thatatvguy
Has anyone tried using a Flowmaster (or pair) on the MINI? Maybe a 50 or 60 series, or even the Deltaflow ones. I have a 50 series Deltaflow on my V6 S10 and it's not "loud" at all. More sound outside, than inside the cab.
A resonator is almost a necessity for getting rid of the drone, but was curious what this setup would sound like.
One thing to keep in mind - the rear of the MINI is not sound insulated at all. Very little sound deadening material used anywhere.
So, you can invest in some Dynamat or =, or deal with the loud. I found this out when working on something for the rear of my car. As soon as I took the carpet and foam, along with the folding parts for the rear seats out, it got louder and noisier. Mainly road noise.
One last thing. The flat orientation of the floor pan and the mufflers causes a perfect condition for an acoustic standing wave. The major contributor for drone.
Old Sep 25, 2007 | 09:52 AM
justintime's Avatar
justintime
dynomax isnt bad but still pretty loud. I too am looking into the same thing. I think im just gonna modify the stock exhaust instead. when my friend ran the milltek it wasnt that bad though. whatever you do dont go magnaflow anything if you dont want noise
Old Sep 25, 2007 | 10:20 AM
sonichris's Avatar
sonichris
the milltek was awesome... until the resonator blew out. now it's too loud. i'm still waiting to here from stratmosphere about replacing the resonator under warranty. i'm going to try that first.
if i had to design a system i would probably use a similar setup to the borla street, but use 2.5" tubing and a straight thru muffler on the front section instead of the 2.25" pipe they use.
Old Sep 25, 2007 | 10:24 AM
justintime's Avatar
justintime
is it just the resonator? I have a magnaflow resonator, its 2 1/4 tubing but hey...
Old Sep 25, 2007 | 02:57 PM
justintime's Avatar
justintime
https://www.northamericanmotoring.co...d.php?t=114407
check that out :]
Old Sep 25, 2007 | 03:06 PM
sonichris's Avatar
sonichris
err... ya see... that one is ALSO blown out. like mine. mine is blown out. i don't want ANOTHER blown out resonator.
Old Sep 25, 2007 | 03:10 PM
justintime's Avatar
justintime
oh... I didn't see it was blown out.. sorry, I'm gonna go play in traffic now
HaveATank
Sep 16, 2015 08:32 AM
patsum
Sep 14, 2015 07:15 PM
Colt45Magnus
Sep 14, 2015 03:12 AM
deputydog95
12
Sep 12, 2015 06:49 PM
Sep 4, 2015 08:25 AM
