R52 Annoying Seatbelt thing...
Old Sep 10, 2007 | 07:43 AM
Oettpo's Avatar
Oettpo
My driver's side seat belt seems to have the male end on backwards. When you pull it over your shoulder to secure it, you always have to twist it to go into the receiver correctly. The belt would lie flat if the male end were on 180 degrees from where it is now. Anyone have this? I know it is minor but, it is annoying. Any ideas or suggestions?
Thanks,
Paul
Old Sep 10, 2007 | 08:49 AM
rc'S's Avatar
rc'S
You probably turned it inside out on the belt at one time or the other. Fold the flat of the fabric belt back over itself inside the slot on the male metal latch. Good as new.
Old Sep 11, 2007 | 12:21 PM
StLouieLo's Avatar
StLouieLo
My seat belt on the driver's side has twisted since the day I picked up the MINI. I have had the dealer look at it & it still continues to do it. It seems to be a problem only with the Cabrios. I wish I had an answer too.
Lois
Old Sep 11, 2007 | 12:37 PM
Mishka's Avatar
Mishka
Lois
I have the same problem with the backseat drivers side belt. It seems the more I try to fix it, the worse it gets. I figure it is from driving with the top down a lot, and the wind is twisting the belt. I have finally decided I don't ride in the back, so I'm not going to worry about it.
Old Sep 11, 2007 | 12:42 PM
RA080624's Avatar
RA080624
thats why i ride with all my buckels buckeled
Old Sep 11, 2007 | 12:55 PM
Mishka's Avatar
Mishka
I normally do to, but they got undone when we had a passenger or the seats folded down, and didn't get buckled back before motoring.
Old Sep 12, 2007 | 06:07 AM
FLMINI1048's Avatar
FLMINI1048
When I bought my MINI, it had the same problem. I was able to fit it by pulling the seat belt out all the way a few times and it fixed itself
Old Sep 19, 2007 | 01:15 PM
ericscottf's Avatar
ericscottf
Oettpo - pull your belt all the way out and see which way it is twisted. Fold it over the other way and put it through the slot. It should work out okay then.
Does anyone else have a problem with the buckle sticking in the latch during ejection? Mine comes out halfway and gets stuck approx. 1 in 10 times, i'm worried what might happen in an emergency, but since i can't get it to happen on command, i haven't told the dealer...
boholio
Nov 9, 2015 03:50 PM
potterstein
Oct 2, 2015 09:30 AM
Oct 1, 2015 12:13 PM
Puggles
R60/R61 Stock Problems/Issues
Sep 11, 2015 11:53 AM
MiniSkoon
Sep 9, 2015 12:40 PM
