Any tq figures available? +1 to listing the mods, please!
178-180 tq range ....
we didn't get a good read on the first run with the tq pickup as it was bouncing on the second run right after it pulled 250.43 and 180
first class of course, so what was the figures at 6850??
232-233whp but it pulled some timing right after... it's still stock timing
there is more in this car. It was also run in 4th gear which really loads up the engine on the old tranny gearing
I have some more stuff to put on this car before we finish
U better send that part over I think I know what it is now cant see how its made that much difference, just goes to show theory is one thing reality is another.
Would you of guessed a result like that??
its combinations of things, you know as well as I do very small changes can make drastic differences. I have been developing a "system" approach and now you are seeing the culmultive effect. I want to tune this thing....
Stock supercharger
stock ecu with rev limit change
stock throttle body
15% pulley
CAI
Revolution Big Valve cylinder head
Revolution CP pistons
Revolution custom header (specific for this application)
Schrick cam (coming out for my grind which should work better with my header)
bigger injectors
something I have worked on but finally put in*****
That is bad.... so when do you think you will be able to tune that monster....
and also were the pistons completely neccasary if you are gonna run a similiar set up to this one?
We hope to have our custom tune back any day but we are waiting impatiently
the pistons are in as this car will be going to the next level after this phase
this will end up a full race application and not your everyday driver
we will have full dyno's on those cars also
Many projects going on at once here at RMW as we are bringing full systems to the Mini community at every level.
The next few months will be exciting as we unveil stuff I have been working on for over a yr.
