Navigation & Audio hard wire of nuvi
The NUVI uses a mini-usb connector. I think Garmin may sell a bare-wire version of the connector. If not, you should be able to buy one online somewhere.
Not sure about significantly changing the factory 12v connector. The easiest thing to do would be to hide a 12v socket in the dash and plug the connector into it.
Double check the output voltage of the lighter adapter. I was ready to cut off the adapter for my XM radio to hard wire it in to the car, but the output of the adapter is 6V. I may get a spare to dissect, although mounting an extra socket is probably the easiest way to go.
rob and the Blue Shifted MINI
hey rob
thanks for the input...yes i checked it nd its a 5 or 6 volt output. i'll have to put in a spare cig plug. i did that on my other mini on the passenger side for my laptop.
any idea which of the wires under the driver side kick panel will be a good accesory on wire?
thanks
bob
thanks
bob
I'm not sure on wiring. My plan is to wire into the lighter. I like the fact that it is switched power. The power switch on my XM is a little flaky - last thing I need is to get in the car in the morning with a dead battery because the radio didn't shut off.
you can go right to the fuse box...it's just that it's on the other side. i do this stuff all the time i just thought someone may have already done it. i'll poke arounf with my metter or just run awire over
bob
bob
I used one of these to connect from the fuse box to the Nuvi:
http://cgi.ebay.com/Direct-Hardwire-...QQcmdZViewItem
thanks for the reply.....i decided to just add a pwr port / cig lighter in the rear of of each footwell...one for my nuvi and the other for my laptop. i used an add a circut for the line
bob
bob
Hey guys,
I'm really confused! Does anybody have a good way to hard wire my nuvi.
1. What voltage does the nuvi need
2. Waht is the barrel resistor
3. I thought to just cut the lighter plug and h/wire it (don't think this is right.
4. Found in other thread about fuse extenders
on and on You see my confusion.
I bought a lighter socket with bare wires at radio Shack. I attached the hot line from the socket to an Add-a-circuit and that went to the fuse box. The other wire from the socket went to ground. Then I plugged the stock cigarette lighter cord into the socket under the dash and ran the wire to the NUVI.
Navigation & Audio Portable Navigation XL Wiring
mikeandtricie
Sep 4, 2015 01:42 PM
Sep 1, 2015 04:02 PM
